Coolant line thru TB...HELP!!!!
Old Sep 18, 2004 | 06:48 PM
XeroX's Avatar
Hella internets
alright, i bypassed the line thru the TB. And i have experienced the problem that everyone describes from doin this..
So im putting it back.. but there are 3 coolant connectors under the TB. i remember only 2..
Anyone have a diagram i can refer to? i need to know where these plug too..
i need this fast...thanks
Old Sep 18, 2004 | 07:26 PM
BadKarma99-4spd's Avatar
not to be a *****, but why the hell would you do this?
and in your defense i can only remember there being 2 lines as well.
i dont have my haynes manual handy right now, do you?
ill check mine when i get home tonight and see if there is anything in there.
good luck
Old Sep 18, 2004 | 08:03 PM
XeroX's Avatar
Hella internets
OK, well i bypassed it because most cars do not have a temp sensor in the TB for the coolant line that passes thru it..
Most cars just have this so that the car has an easier time warming up in bellow freezing temperatures.. SO, i bypassed it so that there would be less heat being projected into the manifold thru the TB. COOLER AIR = MORE HP right?!
Well, i came to realize that my car on the freeway at night would freek out in idle... i would drive at a constant rate at high speeds 50 or above, (in about 60-70 degree) weather, thats cold enough to trick the sensor. The cold air would I GUESS run in the engine bay and go into the empty coolant routes in the TB, and this would make the ECU think that the car was cold. So whenever i would come to a stop after i would get off the freeway the car would be idleing at about 1100 RPMS in drive and about 1500-1700 RPMS in park. THIS is the idle numbers the ECU goes into durring a COLD start early in the morning. So the sensor THINKING the car was cold would trick my ECU into going into the COLD start procedure.
This was a really anoying MINOR problem that only happend at night (cold) and only happened about once or twice a night. sometimes it wouldnt even hapen at all. All along i thought it was a vacum leak. BUT i havent tried re routing this line back to stock, so it might not be the problem.
But please I still need this diagram, i think i have figured it out, but the pics would still be of great help, thanks.
Old Sep 18, 2004 | 09:39 PM
I30tMikeD's Avatar
There are not 3 coolant lines, there are two. Goes in ones side and out the other. In between there is a smaller port which I believe is EGR related. The coolant ones are larger and have bends in them. The middle one is small and straight.
Old Sep 18, 2004 | 10:21 PM
XeroX's Avatar
Hella internets
hmm..
well.. i think i did something wrong, i pluged everything in and there is coolant going everywhere lol...
So maybe there are only 2 lines.. ill take everything apart and check.. maybe this time i will take pics, hopefully its not too dark..
AGAIN, if anyone has pics of this PLEASE post..!!!
Old Sep 18, 2004 | 10:27 PM
Maximum96's Avatar
there r 2 coolant lines and one other 1...make sure u have the other hose in the middle connected in as well...maybe that was part of your problem
Old Sep 18, 2004 | 10:44 PM
XeroX's Avatar
Hella internets
yea but where do they connect? the third one that is?
THere are two one on the far left of the TB and one on the far right. and then the one in the middle....
There is another on farther back towards/close to the firewall...
I connect the one on the far right of the TB to the one by the firewall...and the one on the middle to the coolant line from the radiator closest to the driver fender. the one on the far left of the TB i connect to the coolant line closest to the passenger side fender, keep in mind that this is right next to the other one i just mentioned...the connection from the radiator that is...
Old Sep 18, 2004 | 11:53 PM
XeroX's Avatar
Hella internets
http://photobucket.com/practice.php?id=1awj4
there are some pics...
someone tell me where all these conections go too...
Old Sep 19, 2004 | 06:47 AM
I30tMikeD's Avatar
You are making this way more complicated than it is.
Ok, so you have two coolant lines right under the TB right?...one on the left and one on the right.
All you do is connect those hoses together. It's like a 2 minute job. One hose has the coolant going into the TB and one has it comming out of the TB. So all you do is connect them...hence "bypassing" the TB.
Just use a double sided hollow brass barb on connect the two lines together. You should not have to extend the line, they should be long enough to just connect together.
The smaller "nipple" on the bottom of the TB between the two coolant llines is not coolant related. It is a vaccum source for the EGR system and you don't touch that at all.
Old Sep 19, 2004 | 07:38 AM
matty's Avatar
Are there benifits of bypassing this coolant line to the throttle body ??
-matt
Old Sep 19, 2004 | 02:52 PM
I30tMikeD's Avatar
-matt
It just keeps the hot coolant away from the intake path. I don't really see any reason why it would make a noticeable difference.
Old Sep 19, 2004 | 07:14 PM
XeroX's Avatar
Hella internets
Ok...
So, in the 3rd picture, where there are the 3 circles...only the 2 (left and right) need to be pluged in to the coolant source?
what about the connection (with no hose) in the center? that is left alone?
Old Sep 19, 2004 | 08:08 PM
I30tMikeD's Avatar
Originally Posted by XeroX
Ok...
I can't make your pics real well, but that middle connection I don't know about..that is not the middle one I was refering to. The middle one you have circled is not part of the TB though. The middle one I am refering to is part of the actual TB, just like the coolant ones are.
Was that middle one you had circled connected to anything? Just leave that one be.
Old Sep 19, 2004 | 09:52 PM
matty's Avatar
There is 3 connections on the TB...2 are coolant and one is Vaccum source for the high idle...the vaccum is right on the bottom and the 2 coolant lines are threw both sides..
-matt
Old Sep 20, 2004 | 11:13 PM
XeroX's Avatar
Hella internets
r u sure?
They are all routing together..
the Middle one is the end of the circulation thru the TB.. thats what i have seen on other peoples maxes.. the one on the right of the TB goes to the back.. and it loops thru and back out to the coolant line in the middle..
the one on the left is where it starts...
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
msellas
Sep 23, 2015 09:16 PM
