E.S. control arm bushings help
Old Sep 19, 2004 | 12:42 PM
furbiss112's Avatar
anyone change these on their car? if so any problems with fitment? how did you remove the big bushing at the end of the control arm? i can not get it off. also, the opening for the other bushing is too small. i can not get the bolt throught it. any ideas on whats going on with this? thanks in advance.
Old Sep 19, 2004 | 01:32 PM
Mishmosh's Avatar
The stock bushings have a metal sleeve that often fuses to the control arm articulations. It may be necessary to carefully apply a cutting wheel to the metal sleeves and then pry them off. The front bushings especially may come off and leave the metal sleeve which may look like it is part of the control arm--you need to get that off.
Old Sep 19, 2004 | 03:46 PM
furbiss112's Avatar
thanks for responding. is the control arm under the bushing flat or does it have a barb to help keo the bushing on.
Old Sep 19, 2004 | 05:33 PM
BEJAY1's Avatar
Conecarver
My existing large ES bushing started wiggling it's way out after 2 years. I plan to take a look at what happened in a day or two after I fix this susp swap headache.
Old Sep 19, 2004 | 06:56 PM
gtr_rider's Avatar
192.168.1.1
what he said.. make sure not to cut through your control arm also.
Old Sep 20, 2004 | 03:01 AM
Mishmosh's Avatar
It may have a little nubbins on the end but is held in because frontal movement is not possible because of the front bolt.
Old Sep 20, 2004 | 05:02 AM
mzmtg's Avatar
Minister of Silly Walks
To get the big one off the end, I hooked the control arm over the work bench and knocked the bushing off the end with a hammer.
If it comes down to it, you can cut it off with a hacksaw or something.
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
