wipers not working, fuse seems ok....
Old Sep 21, 2004 | 12:00 PM
pedroboe's Avatar
Hi All,
I tried to do a search, but I do not have priviledges for that. I did a long trip yesterday, from Zacatecas to Guadalajara, here in Mexico. My wipers died during the trip. I check the fuse that I think corresponds, it's a 20 amp fuse in the middle row. It seems fine and I even swapped it with another. The winshield washer is also not working. Any ideas before I submit my *** to the Nissan dealer here?
Pedro
Old Sep 21, 2004 | 12:17 PM
Kevlo911's Avatar
Kevlo for President
Maybe the swtich/stalk(spell?) is bad.
Old Sep 21, 2004 | 12:25 PM
pedroboe's Avatar
thanks
would that affect the washer fluid motor too? it's also not working...
Old Sep 21, 2004 | 12:34 PM
Kevlo911's Avatar
Kevlo for President
Well if the swtich is bad, it would not send a signal so nothing would respond. So when you move it up and down or pull it towards you, the switch does not respond.
Old Sep 21, 2004 | 12:37 PM
pedroboe's Avatar
Thanks a lot, that should be an easy swap....
Old Sep 21, 2004 | 12:40 PM
Kevlo911's Avatar
Kevlo for President
BTW if you don't have inermidiate wipers, it would be perfect to replace hte switch with the ones that have it. Look in hte how to's for it.
Old Sep 21, 2004 | 12:52 PM
ny96max's Avatar
i would check over ALL fuses in the car, including the ones under the hood, sometimes a misc. electronics fuse that blew could cause them not to work instead of the normal wipe fuse.
Ant
Old Sep 23, 2004 | 10:46 AM
pedroboe's Avatar
The problem gets interesting.... switch seems ok, had it tested. Fuse seems fine and the realy seems ok too. I wonder what else I should look at... any ideas? Like I said, the wipers AND washer pump died suddenly with no warning.
Old Sep 25, 2004 | 01:21 PM
pedroboe's Avatar
ok, all is solved now.. a friend checked everything with a test light. It turns out there was a false contact in the fuse holder and it had gotten fried a little. easy and free fix!!! but is one of those things that drive you crazy, trying to find out what the freaking problem was!
tsi6001
Oct 3, 2022 10:23 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
