Funny noise on cold start up 95 SE auto
Old Sep 22, 2004 | 05:11 PM
  #41
Mr. Maxima's Avatar
What the mileage on your I30 now? And why not just buy a older car that is cheap to drive back and forth that you dont car about?
Old Sep 22, 2004 | 05:20 PM
  #42
kkashi04's Avatar
It's got 130k now.
Old Sep 22, 2004 | 06:02 PM
  #43
s0ber's Avatar
dont go through the hassle, its a good car.. Just replace it the chain with a local mechanic, unless you want the headache of looking for another VQ.. I looked for like 2 months before I found my maxima, they were all torn and beat the hell up :\
Old Sep 22, 2004 | 07:22 PM
  #44
ukmastermind's Avatar
if i have this prob..few secs @ start up.....how much longer before all hizzell breaks loose on me? currently 108k, 95, se...just curious to see how long i can squeeze by..fundage is LOW
Old Sep 22, 2004 | 07:31 PM
  #45
s0ber's Avatar
Dont worry about it until it starts doing it when the cars fully warmed up and lubed.. then you have a tensionor problem.
Old Sep 22, 2004 | 07:38 PM
  #46
Mr. Maxima's Avatar
I agree with s0ber.
Old Sep 22, 2004 | 07:39 PM
  #47
nissanguy8's Avatar
I had my GF start the car this morning when it was cold and I listened to the engine, it sounded mostly like it came from the starter, so there is hope that its not that much noise coming from the left bank of the motor (the front where the coolant reservor bottle is) so I am going to replace the starter soon and see what happens.
You should all do that too if you haven't already, open the hood, and listen to it start and put your head in there and really listen to where its coming from.
Old Sep 22, 2004 | 07:45 PM
  #48
s0ber's Avatar
stick a screwdriver or a pipe or something on the timing chain cover, put it on ur eat and crank it up
Old Sep 22, 2004 | 07:51 PM
  #49
95BLKMAX's Avatar
Just fix your car tortuga. It's no surprise seeing a VQ run 200k miles and not need an overhaul (I'd like to see an American engine do that, I should know, both my parents have fords that are falling apart while all I do to my car is change the oil, hehehe).
Bump A32Matt's question, I'd like to know that too please.
Old Sep 22, 2004 | 08:01 PM
  #50
95BLKMAX's Avatar
Sober's ghetto stethoscope= a screwdriver to the ear, lmao. That's a new one
Old Sep 22, 2004 | 08:28 PM
  #51
astorialbo5's Avatar
yo guys before you go through all of that check this site out. someone mentioned it before but didnt write it correctly. its MOTORVATE.CA its like a maxima site and go to Engine and then it has an option Starter Noise Fix. i never new about this site it seems ok. anyway check it out.lada
Old Sep 22, 2004 | 09:34 PM
  #52
daveyg68's Avatar
My starter went in my 95 a while back. Bought one from a junkyard for 25.00 and now she works great. I'm going to try this on my 96 before I settle on the timing chain tensioner theory.
Old Sep 22, 2004 | 11:04 PM
  #53
s0ber's Avatar
lol it works!
Old Sep 23, 2004 | 08:13 AM
  #54
jvairin's Avatar
No, that's not new. . . old timer mechanics used that trick.
Old Sep 23, 2004 | 11:25 AM
  #55
f550maranello2's Avatar
yo my car makes noise like that when i first start it in the morning or at nigh when its cold it makes its like for a while i think it is the starter cuz thats where the noise is coming from not the timing chain. ill check it out tonight ill tell u guys whats up when i do it. by the way the screw driver trick is funny but its the oldest thing in the book. just wanted to add that because its funny when someone does it lol
Old Sep 23, 2004 | 03:11 PM
  #56
Who's Avatar
Who
Originally Posted by daveyg68
... Anyone know if there is a spring release for the tensioners or if it's hydraulic?. ..
There is a spring but it isn't the main supply of tension. I think the spring is just there to keep the tensioner from falling out when there's no oil pressure. The spring is soft so the tensioner is pretty easy to remove and replace. Hmmm....maybe nothing is wrong with the tensioner and it's just the spring that gets weak with age.
The hardest part of the job is the removal and installation of the timing chain cover. I managed to do it without removing the upper part of the oil pan. Haynes manual said to remove it but that looked like too much work. My tensioner was good, well at least I thought is was good, but I had to release the tension to remove my water pump.
Old Sep 24, 2004 | 01:54 PM
  #57
i used a cut off garden hose as a skethoscope type thing..clacking noise comes from top of the engine where timing chain resides.
Old Sep 25, 2004 | 11:41 AM
  #58
20V6's Avatar
Hopefully it's the starter!
But I noticed this strange sound after cold starts a while ago too, just for a second or two after start-up. Turned out I was using a non-genuine oilfilter that didn't have a antidrain valve. After oil and filter (OE Nissan) change the noise is gone.
BTW, the oil pressure light would go out exactly when the noise stopped....
Old Sep 26, 2004 | 08:49 AM
  #59
nissanguy8's Avatar
Thats cool that I ve started a post that 50+ people responded to!!!!!!!!!!!!!!!!!!!
Old Sep 26, 2004 | 09:12 AM
  #60
nissan_man's Avatar
9/23/04 I went out to start my car and it wouldn't crank over. Four days prior I had noticed the car starting to sart slower than normal. So I suspected it was time for a new battery soon. This time when it wouldn't crank, I thought it was a little odd because usually when the battery is dead and I try to start it i hear a repetative clicking noise. But not this time, the lights, radio, etc all still worked full force. Well AAA came tested the battery and deemed it "dead". They jumped me and she started right up. Replaced the battery with a 640 CCA rating and immediately noticed the car still started slowler than normal , but not so slow to where it was obvious. In fact someone not familiar with how my car usually sounds might not find the start speed abnormal. Anyhiw, I drove 7 min to my destination, turned car off came back and the same thing -- had my accessories working but no crank. I attempted to jump it with a 2000 Mazada 626 and that didn't get it. AAA came out again tested this new battery and it came back "good battery". So we then thought it could be the starter or the alternator. Well if it was the alternator the "good battery" should still at least start the car. The starter never hinted at going out other than the talked about rare "humm" that intermittently occurrs due to drying grease or something like that. Well I opted we try to jump it again but this time use a larger vehicle. Got an '84 Crown Vic station wagon to jump me and to everyone's suprise except mine, she started right up. With that I went 7min back to return the battery turned off the car, then attempted to start it back just to see. No start! Autozone tested the battery and it tested fine. AAA using their tow truck attempted to jump me but it was unsuccessfull. On 9/24/04 I replaced the battery with a Die Hard and it is still doing the same thing.........accessories but no crank.
So here is my question, do these cars take a special heavy duty battery? or are the starters for the 1997 maxima problematic. Has any one else had to replace their starter? If so what symptoms did you have that it was going bad? Thanx for any feedback!
P.S. I have no after market accessories on my car
Old Sep 26, 2004 | 09:29 AM
  #61
nissanguy8's Avatar
is it slow cranking?
Old Sep 26, 2004 | 09:40 AM
  #62
nissan_man's Avatar
This past Monday was the only sign I had that something was out of the ordinary. It cranked slower than normal but not obviously so. Now it doesn't crank at all. I can only here a click in the solenoid when I turn they ignition key.
Old Sep 29, 2004 | 01:09 AM
  #63
ok heres the situation: start up loud tap tap tap noise for about 1-2 seconds...goes away....but when car is fully warmed i hear a tick tick tick sound from under the hood. no where near as loud as the start up sound, but does this sound like a tensioner issue?
also i had to redo the cam shims on all the intakes..that was a caca mess
Old Sep 29, 2004 | 09:37 AM
  #64
s0ber's Avatar
tick tick.. sounds like your injectors.. there all annoying and loud..
the 2 second tap tap tap sound like the timing chain not getting any oil for them 2 seconds..
I wouldn't worry about it until it starts doing the tap tap tap after the cars warmed up and fully oiled.
Old Sep 29, 2004 | 01:15 PM
  #65
98SterlingMax's Avatar
Humble '06 TL Owner
There is a lesson here...use the Nissan filter. I used to use Fram and always wondered what that 1 second clatter on the cold start was. Changed to Nissan filter and problem solved.
Old Sep 29, 2004 | 04:24 PM
  #66
Wmaxima's Avatar
What does enerybody think of K&N oil filters which are ($12.00) cause i still have that chatter on cold start ups
Old Oct 9, 2004 | 11:08 AM
  #67
kkashi04's Avatar
I finally got the sound recorded. You have to turn up the speakers. Listen to both. It just so happens it sounds like a friggin tank crossing by when it was recorded.
http://64.45.19.205/I30/
Thanks.
Old Oct 9, 2004 | 11:23 AM
  #68
96_Infiniti_I30's Avatar
My GF has a 95 SE auto and when you start it up in the morning or the car has been sitting for quite a while, there is this weird mechanical noise and it lasts for like a second or 2 after the car starts, I have no idea what it is and I don't think the starter is going out.
I have a feeling its the timing chain tensioners or something inside the engine, does anyone have any thoughts on this? The car has 107K on it.
my car makes the same noise when its cold out.its normal for some of our cars,some make the noise some dont.
Old Oct 9, 2004 | 12:37 PM
  #69
nissanguy8's Avatar
man that sound doesn't sound right! mine sounded nothing like that
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
Justin Kroll
Sep 2, 2015 11:06 AM
FlaMark
Aug 21, 2015 11:06 AM
