why use high octane in 97 se?
Old Apr 9, 2001 | 03:40 PM
hash's Avatar
Just bought a 1997 se and don't have an owners manual do I have to use high octane in my max at all times. Also why is it that I can roll my windows down with my keyless entry but cannot figure out how to put them back up with the remote, is it possible. Happy to say that I just did my first mod CLEAR bumper lenses man what a diff.....really like wicked's grills those are really nice anyone know where you can get those cheaper then godfathercustoms.com..........thanks
Old Apr 9, 2001 | 03:59 PM
GarthG's Avatar
Yes 92+ octane is required for all Maxima's from at least 95 and up, maybe even 92-94 SEs also. You could put a lower grade in but the car has a knock sensor that will retard performance of the car, and people have been known to have smog problems if they use lower octane.
As for rolling the windows up with keyless, there is currently no way to fix this, it only allows us to roll them down. We are waiting for instructions from another member who said his dad wired the window so that when you lock the car the windows rolled up also, but we don't know when they will be available.
Old Apr 9, 2001 | 05:23 PM
BriGuyMax's Avatar
Actually, Premium (92+) is not REQUIRED for 95-99 maxs...if you read the owners manual (and inside the fuel door), it's only RECOMMENDED for "best performance." Whatever that means. I have run both 87 and 93 in my car, and the only thing that I have concluded is that it seems to run smoother and get a little better gas mileage with premium...but it might just be in my head. So I always use premium for piece of mind.
and, no the VQ engine will NOT retard performance if you use lower than 92 octane.
Old Apr 9, 2001 | 05:28 PM
Eric L.'s Avatar
Super unleaded is NOT required, despite what all the gearheads here will tell you. The owners manual recommends high octane gas. This allows maximum compression for maximum power. However, I would be surprised if using super vs. unleaded yielded any measurable (much less noticeable) difference in performance.
And for those people who say that they use super because it's worth the extra fuel economy, think about this: for me, regular is $1.89/gallon while super is $2.09/gallon. That's approximately 15% more to buy super unleaded. Do you really think super will give you 15% better fuel economy? We're talking 2-3 MPG here. I don't think so.
Personally, I use super unleaded in my car. That was the gas the engine was designed to run on, and well, it's for my peace of mind. However, I have used regular on occasion and did not notice any difference in performance or fuel economy.
So, in conclusion, use super if you want to, but you do not have to.
Old Apr 10, 2001 | 05:46 AM
zagato27's Avatar
Gas
I've noticed that when I have used regular unleaded (infrequently) that there is a "pinging". I'm sticking with premium. Wellll, at least until gas prices start shooting up
23.8 mpg yesterday
Old Apr 10, 2001 | 06:36 AM
MikeyMax's Avatar
gas
I was using 87, then I recently changed to 92...
not much different, but I heard the VQ engine is sesitive. I tried 92+104 octane booster, and my mileage went up 29 miles per tank.
Old Apr 10, 2001 | 07:22 AM
Shingles's Avatar
The missing moderator
Just wait till when it's about 100 degrees out side. Then running on 87 won't seem like such a good idea anymore.
-Shing
Old Apr 10, 2001 | 08:44 AM
Daniel B. Martin's Avatar
Several posts in this thread mentioned Nissan recommending fuel with 92 Anti-Knock Index. My Owner's Manual calls for 91 AKI.
Most stations sell three grades of gasoline: 87, 89, and 93 AKI. I fill with equal amounts of 89 and 93. That's the economical way to buy 91 AKI.
Old Apr 10, 2001 | 01:43 PM
Dave B's Avatar
Not DAVEB the parts guy
My manual say 91. The highest I can get is 92.
Yes, running lower octane WILL decrease performance. Why? Because the Maxima has a 10:1 compression ratio motor which is considered high compression. High compression motors generate more cylinder heat due to the higher compression. Octane ratings on fuels are related to their ability to burn. Higher octane means a higher temp for burn. If you put 87-89 in the VQ and your motors hot, it will detonate. Detonation is when there is so much heat in the cylinder that the fuel ignites without a spark. This is very bad and can completely destroy the motor. How does the VQ compensate for this? The Knock Sensor. When the sensor hears the knock (detonation) it tells the ECU to pull the timing which then ultimately takes away power and mpg. Pulling out a lot of timing will really bog down the motor. Even on a hot day and running 91 octane, the VQ will show signs of detonation and reduce timing. Running 87 could really make things nasty.
Why do you guys think cars that have NOS, turbos, or SCs run super high octane? No, it's not to be cool, it's because these power adders generate massive cylinder pressure and heat. When you compress air, you generate heat.
Run what the manufactuer says to run. Don't run anything less unless you want worse performance at all levels.
Dave
Old Apr 10, 2001 | 03:04 PM
MaximaRider's Avatar
Eric L.
Where the hell do you get your gas, i feel sorry for you man ,i get my 92-93 Octane for $1.59, not $2!!! Gas bills suck especially when your a teenager even if it is only 1.59.
Old Apr 10, 2001 | 09:22 PM
GarthG's Avatar
In Cali, Premium is consistantly around $2/gallon. . . It gets higher towards the bigger cities, but you dn't hear about it until it reaches $2 in Chicago or a place like that. . . We get no love.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
