how much do coil packs cost? what does infinit resitance read?
Hey guys...
I was measruing my coil packs and i'm getting different resitance values for each coil pack?!?!?!
how do i know when they might be completely dead? when they have a high resitance value?
I'm assuming infinite resistence means that i should see a zero value on my multimeter when i read the coil packs values?
Thanks guys!!
Thanks guys!!
infinite resistance is 1. if your getting like 1000 + or - then its not functioning properly.
they cost $55 from www.jrnissan.com use "Maxima" promo code to get 25% off.
another gave me 85.8...
i assuming the coil is more dead the more the resistence value goes up?
could really tell you. if you get a resistance other than 1, then you should replace it. your car will hesitate over time, and after that happen's then i believe your fuel injectors may go as well. since your replacing your coil, you might as well order some NGK copper Spark plugs. and replace them as well.
I kept wondering what an infinite resistance would look like... hehe
But yeah, hopefully this will fix my idle problem... ( rough idle, sometimes stalls randomly... other times the car is strong as hell in the low end...)
aminus21
Sep 12, 2015 04:53 PM
sdotcarter
Sep 2, 2015 09:53 PM
