can a faulty TPS be the cause of failed smog check?
Old Sep 22, 2004 | 11:02 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
the last time i went to get a smog check, i failed for 2 reasons;
1. ECU fault code: P0105 MAP/BARO CKT Malfunction
and
2. I failed the 15mph test. my No (PPM) level was over the max, infact all my levels were pretty high. but i passed the 25mph test.
lately my RPM has been fluctuating. it use to idle at 650, but now when i will stop it will be anywhere between 650 and 1000, and sometimes slightly above 1000. could the higher RPM be the reason of my high emissions? also, what does that ECU code mean?
im going to try it out again later this week and what i am going to do is clear the code, drive around for a little bit and if it doesnt come up again ill go in. is this a good idea or could there be added problems?
Old Sep 23, 2004 | 12:54 AM
happyricefob's Avatar
V^___^V
were you running lean or rich at 15mph?
btw i looked up 0105 for you...it's actually Fuel INJ Sys Right bank.
Old Sep 23, 2004 | 12:55 AM
V^___^V
Originally Posted by Shadow1198
I know this has been addressed many times here before but I wanted to make a new post that addressed all of these problems as a result of a single part rather then many different malfunctioning parts. All of these problems can be caused by lots of different things BUT, there is one thing in particular that can cause all of these problems by itself. The part is the Idle Air Control Valve (IACV).
Basically, over time carbon deposits can build up on the valve and cause it to stick. If it sticks, it can cause the TPS sensor to not work properly which can cause the snowball effect to begin (leading to more and more problems). Here are the following problems I had and my diagnosis of them (you'll begin to see the "snowball" effect this little b@stard valve can cause!):
-Lopy idle (a result of misfiring)
-Running extremely rich in low-end and at idle (real-time diag on ECU)
-Running lean in the top-end and throughout most of the rpm band (real-time diag on ECU)
-Misfiring (a result of running so rich at idle/low-rpm)
-Missing/bogging low-end (running too rich will bogg the engine down)
-Missing/bogging high-end (running lean can have the same effect as running too rich)
I've been having ALL of the afformentioned problems. Basically, my whole entire power band seemed to be lacking. It all boiled down to the IACV. My IACV was clogged with carbon deposits, which in turn caused the valve to stick. Because the valve was stuck, this can cause air to be entering through it when it is not supposed to. A direct result of this is that the TPS sensor will not function properly, and replacing/adjusting the TPS will have no effect. With the valve stuck, a direct result is also to cause the engine to run rich with the throttle closed and low-rpm, as well as running lean through most of the powerband. Running so rich and lean at the same time can also cause your Maxima to misfire a lot and have a lopy idle. With the TPS not functioning properly the throttle doesn't quite act right in that it takes awhile for the rpm to fall. This can be seen in engine braking, revving with the clutch pedal in or in neutral, etc. Basically, after 2yrs of diagnosing these d@mn ECCS gremlins I found out MY problem. All I did to fix all of my problems was remove the IACV and spray carb cleaner through it to clean all of the deposits off. After 2yrs of replacing parts and dealing with this crap, I solved my problem in 5min (the parts I replaced helped of course)! One thing I should state is that out of all the parts I replaced, none of them really had much of any effect on the problems I was having. Cleaning the IACV is the only thing that has drastically changed/eliminated these problems. So far, everything is working great but I haven't put any serious mileage on my car since fixing this. I'm going to fill up with gas today and see how my mileage will be affected. I'll respond later next week to let people know if cleaning the IACV really has helped me that much with performance, gas mileage, etc. I replaced the following trying to fix all this crap:
-spark plugs
-wires
-dist cap
-rotor
-air filter
-fuel filter
-pcv valve
-ignition coil
-MAF
-cat
-o2 sensor
-tps sensor
Now, this IACV valve is really tricky because I have seen lots of other posts where people with similar problems have replaced the TPS, EGR, FPR, etc and it doesn't help plus the problems continue. Let me tell you this, CHECK THE IACV!!! I never thought that simple little valve could cause all the problems I was having but the fact is, it was pretty much the single reason I was having ALL of those problems! There are, of course, many other things that can cause these problems. So, cleaning the IACV might not work for everyone but, it is definitely something you should at least try.
according to your problem, i thought this was valuable information...i would start cleaning the IACV and reset your ECU.
Old Sep 23, 2004 | 09:20 AM
Vlasic's Avatar
woah thanks. ill get on that right away, that helps a lot.
as for that code 0105, that means that the right bank of the fuel injection system is malfunctioning? does that mean ill have to replace some fuel injectors?
gustavison
Oct 4, 2015 06:50 PM
JoshG
51
Sep 21, 2015 10:41 PM
Jay556
Sep 12, 2015 05:50 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
