Help! I was trying to do a diagnostic...
Ok, not a diagnostic-but this "ECU fault code diagnosis". I did like it says and turned it clockwise then counterclockwise. Then, I looked at the light and it was off! So, it never did the blinking thing-it just went off?! Are you with me?
Originally Posted by SprintMax
press your remote button 2 times, start the car up, drive 2 miles, go back to your original location, press the remote 3 times and the light will come back.
Originally Posted by Sassy Girl
WOW! You guys are amazing-for real!!
Anyone here from Minneapolis? I just went to start the car and it starts and shuts off! I think I am going to cry!
I turn the key and it runs really rough and shakes and then the car just sputters and dies.
But, it's probably the johnson rods.
Ok, I just went out and tried to start it again-It will not start!! I called my friend who I bought it from and he said it has never done this to him. I got it started one time but just for a couple of seconds then it shut off!
Originally Posted by EvilRoadsVictim
I would change the battery energy modulator and see if that fixes it. Common problem.
Well the procedure is outlined in section 11D of the electrical systems manual. You have to start from somewhere...
She can probably find at least one of the problems by analyzing circuit three:
this happens to me when i do the diagnostic check also.. i start the car, it drives hard for a few seconds, then say at like a stop light or something, the car will shut off.. but once i get it started again.. i drive at a good speed for a while and it doesnt do it again. it only does it when i reset my ECU..
This HAS got to be someone f*cking with us. IP check please.
Ben / Evil - I'm weeping here...
Johnson Rods... lol... where is that from again?
By the way guys, stop jerking the poor girl around. Seriously.
We all know it's the serpentine belt.
serious... I have actualy done something similar, and the problem was, I forgot to turn the ECU screw back to it's original position, go down agin and check, which way is the screw turned (couterclockwise or clockwise.)
