Hello Every One Im New to the Site.
Old Sep 28, 2004 | 11:24 AM
Wise's Avatar
I'm have problems Pumping gas @ the gas station. For example, if I pull the gas trigger all the way back, gas comes back and start to spit out every where and the tank is not even close to full. I have to pump the gas extra extra slow to avoid the gas spitting problem. It take me at least 8 mins to Pump $25 worth of gas into my car. I have a 1999 Maxima GLE edition. I need help. What is the problem i 'm facing? Thanks people i will get back soon.
Old Sep 28, 2004 | 11:36 AM
A32Matt's Avatar
wow, that's really not good. 8 min. to pump $25 into you car. sounds like something is restricting the gas causing the auto shutoff to kick on. you might want to have your fuel neck and fuel restrictor plate checked out to see if somethings clogged or jammed. i had that same problem on my old '86 Bronco, never found out what it was though.
Old Sep 28, 2004 | 11:38 AM
mzmtg's Avatar
Minister of Silly Walks
You should post this on a gas station forum or something because you need a "how-to" write up for using the pump.
Old Sep 28, 2004 | 11:52 AM
Duck's Avatar
Hey Wise... I am new here myself!
Just an observation... Maybe its bad gas, and your car is trying to tell you something???
Old Sep 28, 2004 | 12:46 PM
jdm71488's Avatar
maybe someone shoved some paper, or cotton in there... from the way you described it, gas goes in, but since the flow of the pump is faster than the diffusion would allow, it spits up... just my thoughts...
Old Sep 30, 2004 | 07:35 AM
Maxima99SE's Avatar
will fly for food
if youre talking about an 86 bronco I (the big one) then I feel bad for you... my dad's got a 96 eddie bauer, and it takes long enough to pump the $60 or so as it is...
Old Sep 30, 2004 | 07:45 AM
sean05's Avatar
Welcome to the org haha you will become addicted to this site. It has everything you will ever need to know about max's. Everyone here is usually very nice and helpful. Check updated with you local section for meets and stuff. There always a blast.
To the gas, do anyone has anything out for you? You **** anyone off lately? Sounds like something is clogged in the neck. I was going to say stick something in there and see if anything is stuck but i dont know if that would help of not, could make things worse Maybe take it to a shop? Maybe spray some compressed air in there. Is it just at 1 station? Try other gas stations. Good luck.
Sean
Old Sep 30, 2004 | 07:48 AM
ManualMaxima's Avatar
5th Gen till she dies!
lets give him a 5 pager like Mrs. Maxima got!!!! Welcome to the .org, how old are you, what your names, how do you like your pancakes????
j/k
Old Sep 30, 2004 | 08:36 AM
chrish09's Avatar
def sounds like something is blocking the flow, bring it to a local shop and see if they can scope it out
Old Sep 30, 2004 | 08:41 AM
mansurxk's Avatar
yeah, is that little lid thats at the top of the neck still attached? i had it break off and fall in on my dad's car (altima) wasnt allowing enough gas to flow through
Old Sep 30, 2004 | 08:56 AM
Rick James's Avatar
j/k
lol
MaximaDrvr
Aug 19, 2015 08:20 PM
Viralkill
Aug 15, 2015 11:52 PM
