300 zx breaks and rotors and injectors
Old Sep 28, 2004 | 06:13 PM
2 Da Max's Avatar
ok so my boy crashed his 300zx and he said hell sell me all the rotors and calipers and whatever has to do with the brakes for 150. my question is, would this fit my car or shouldi take his spindle, wait i cant cuz his car is rwd. neways what do i need for this 300zx brakes to work on my car?. o if i am not running no type of forced induction would it make a difference if i used his injectors neways? thanx for the input guys
Old Sep 28, 2004 | 06:21 PM
MDeezy's Avatar
If he's willing to sell you all his brake parts for $150 I would take it, thats a sweet price. you can use his calipers on our cars, not sure how to install, but I would take it cause I'm sure its not cheap nor easy to find calipers for the 300zx since they dont make it anymore, and it cant eaily be found in a junk yard (my 2 cents on that)
The rotors I'm not sure, but dont think you can use them. His injectors, would be sweet if you had some FI, but since your NA it wont do you anygood, if you putit in I think you would just run rich and burn a lot of gas.
You should get his MAF if you can, wouldnt hurt to have it around just in case.
Old Sep 28, 2004 | 06:25 PM
Jason R's Avatar
aka UNCDooD
what year is his 300zx and is it TT?
Old Sep 28, 2004 | 06:30 PM
z32drifter's Avatar
I would grab all the brake parts.... make sure you get the hoses and hard lines on the calipers.... the rotors have to be machine to fit.... search for 300ZX brake upgrade.. you will find all the info you need.... the calipers will bolt on... make sure you get some washers to space the bolts a cpl mm...so they don't go all the way thru the caliper... injectors would require reprogram of the ECU of an AFC to work... not worth the trouble with out major mods or FI.... and don't forget your stock wheels will not fit over the 300ZX brakes
Old Sep 29, 2004 | 07:19 AM
Nealoc187's Avatar
SLOW
if the car is a 95 or 96 TT then you should definately get the injectors. you would not want to use them but you could sell them for a few hundred bucks. if it isnt a 95-96 TT don't bother with the injectors.
Old Sep 29, 2004 | 07:49 AM
sagamax's Avatar
Give me a Bud Light Holmes
what size are the injectors before 95-96 on the z32 i though they were all 370cc
Old Sep 29, 2004 | 08:08 AM
Nealoc187's Avatar
SLOW
they are all 370s in the TT but they aren't all direct bolt in. only the 95-96 TT injectors will go in without any modification.
Old Sep 29, 2004 | 09:14 AM
Jason R's Avatar
aka UNCDooD
if its a 95-96 TT hook me up with a price on those injectors.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
Socalstillen
Sep 26, 2015 12:01 PM
