STARTER...OEM or AFTERmkt?
Old Sep 29, 2004 | 11:34 AM
Millwoodva's Avatar
Starter will not crank every 10th time or so. Only a 500 mile owner ('98 SE 90,000 miles) so very new to MAX repairs and venders.
Old Sep 29, 2004 | 11:36 AM
PTownMax's Avatar
I still miss the max
had to deal with that like last week, i went with oem, i don't see the point in aftermarket, that starter was chosen for your car for a reason
Old Sep 29, 2004 | 12:02 PM
s0ber's Avatar
I Replaced mine a few months ago with a autozone starter.. lifetime warranty.. No probs so far.
Old Sep 29, 2004 | 12:33 PM
MDeezy's Avatar
Starters are easy to change out.
My OEM went dead on me, and I replaced with an AutoZone with Lifetime warranty, that one went out on me in about 4 months, replaced it, and now it feels like its going dry again, going to take it in and get it tested, I'm just glad I have a lifetime warranty on it.
I would lean toward an aftermarket, but if mine is going to keep going out every 4 or so months, then I might just go OEM, the price difference in about ~$100.
Old Sep 29, 2004 | 02:31 PM
bkea's Avatar
The starters from autozone and advance auto come with a life time warranty, which is good cause you will need it. The expensive ones from other sources are usually alos rebuilt and will only come with a one year warranty. It ususually fails just after that. The best thing to do if you are going to keep the car is try to get an new one from a Nissan dealer. It will cost though.
Old Sep 29, 2004 | 02:34 PM
Micah95GLE's Avatar
When the factory starter went bad in my GLE, I had it replaced with an aftermarket one (not Autozone, but I don't remember the brand). That starter was about half the price of a Nissan starter and lasted longer. I never had a single problem with the aftermarket starter.
Old Sep 29, 2004 | 02:57 PM
The_Bomb's Avatar
Aftermarket starters are usually if not always just rebuilt Nissan OEM ones. If you look on it you will still see the Nissan Logo... maybe painted over but it is there. They are cheaper and have lifetime warranties... they take about 20 minutes to change so why not use a cheapo Autozone one?
Adam
Old Sep 29, 2004 | 06:31 PM
1996blackmax's Avatar
I've had my Autozone one for a few months. No problems so far .
Old Sep 29, 2004 | 07:37 PM
ThurzNite's Avatar
I got the autozone one. Died in 6 months. Good thing for lifetime warranty
http://thurznite.maximaclubca.com/pi...012%20Starter/
Oh yeah, funny thing... Autozone guy cross-referenced the starter and said it's also used in Fords. So who knows, maybe the starter you get will be a ford.
Jae
Old Sep 29, 2004 | 08:59 PM
nissan_man's Avatar
OEM? I'm not to impressed with the life span of my original starter in the first place. Did Nissan redesign the starter's for the '97 max? If not, there's no advantage to going OEM. The original one on my max is an Hitatachi. If there is a better brand out there, please let us know. I'm told to try a BOSCH. Whatever the case the notorious starter issue should be billed to Nissan. Besides the '95's any TSB's for the 10 tooth trash in my '97?
Old Sep 30, 2004 | 07:00 AM
Pappa Grande's Avatar
As stated above, both autozone and pep boys (in NJ) have Life time warranties. I just bought the pep boys starter for ~$159 with core. Autozone's is only $139 (wish I knew that before). If you plan on keeping the car a long time, get the aftermarket. You very well may need to change it. Also note that replacing a starter is NOT a hard job. Its a good place to start if you want to work on your own car...
Old Sep 30, 2004 | 01:49 PM
jbreit's Avatar
there was an 8 and a 10 tooth starter. I thought the 10 was supposed to the better..? Anyway, my rebuilt was an 8 tooth, and they will both mount up just fine. Bought a lifetime unit from Autozone for the same prices listed above...a year and a half in Wisconsin with no problems.
Anytime you have to turn in your old parts you are getting a rebuilt unit....water pumps, drum brake shoes, calipers etc.
There are some shops that specialize in rebuilding starters and alternators and they generally beef up the weaknesses of the OEM stuff....look in the yellow pages. But they usually takea day or two to turn them around unless they have one sitting on the shelf, which is rare.
Good luck,
JB
Old Sep 30, 2004 | 02:03 PM
Ant96GLE's Avatar
YOu guys are clueless with what they sell you at an auto parts store.
What you get at an auto parts store is a rebuilt OEM starter. You know how you bring your old starter back as a core? Thats because they go and rebuild that same old one and sell it to someone else.
Just get a regular Autozone one with a lifetime warranty and you'll be fine. Atleast our starters are VERY easy to change. I did mine in about half an hour.
Old Sep 30, 2004 | 02:05 PM
Ant96GLE's Avatar
Good luck,
JB
No!!!!!!! dont go around with how many teeth are better... the teeth line up with your flywheel so if the number of teeth dont add up, your either going to mess up your starter or grind the teeth off your flywheel.
When you take off your old starter, count the # of teeth on it and count the number of teeth on the new one, it should add up.
maxi98
Oct 23, 2001 06:39 PM
tclee
Apr 24, 2001 01:57 AM
Bernie Lomax
Dec 19, 2000 03:25 PM
tclee
Sep 14, 2000 02:10 PM
