Error code 510?
Old Sep 29, 2004 | 04:33 PM
Grifflewis's Avatar
Error code 510?
Check engine light came on. Did the diagnosis as stated through http://vbxmaxima.8m.com/ecu.html. Got the error codes 0304 and 0510. I had already taken my car (99 GLE) to Autozone and they ran a diagnosis on it as well and they told me I was getting a Knock and O2 sensor error. They never told me the actual numbers to the codes though. 0304 I know is a Knock sensor error. I can't find what 0510 means though. I've seen it listed as a Closed Throttle Position sensor and O2. Can anyone elighten me as to what it actually means?
Autozone recommended I start with the O2 senson b/c sometimes it can cause the Knock sensor to go off. Anyone know if this is true? And if I should start with the O2 sensor, which one do I change? From what I've read there are 2 O2 sensors.
Any help would be greatly appreciated!!
Thanks!
Old Sep 30, 2004 | 11:34 AM
S103100F's Avatar
i think 0510 there is no such a code
0304
Diagnostic Trouble Code 0304 points to a problem with the Knock Sensor. The KS is attached to the cylinder block. It senses engine knocking using a piezoelectric element. A knocking vibration from the cylinder block is senses as vibrational pressure. This pressure is converted into a voltage signal and sent to the Engine Control Module (The computer).
This malfunction is detected when an excessively high or low voltage from the KS is entered to the ECM. Possible causes include...
- the harness or connector (The KS circuit is open or shorted).
- the KS
The KS may be checked with an ohmmeter.
1) Raise the hood. View the engine from the driver's fender. Look into
the deep valley between the cylinder banks and below the intake manifold.
Identify the KS as a black item fastened to the block by a single vertical
bolt. A wire harness wrapped in black leads toward you, out of the valley.
That is the KS sub-harness.
2) Follow the KS sub-harness to it's nearest connector. This is connector F121.
It is located near the upper right-hand corner of the valve cover of the forward cylinder bank, as viewed from the front of the car.
3) Disconnect F121. You have to do a "press the latch and wiggle and
pull" to disconnect it. F121 has only two pins; if you see more than two
pins, you have the wrong connector. Use a digital ohmmeter capable of
measuring more than 10 Megohms. You want to measure the pins of F121, not
the sockets of the matching connector. Measure the resistance between a
good ground (such as the battery negative terminal) and pin #2 of connector
F121. On my car this is the highest of the two pins, the one closest to
the front of the car. The factory spec is 500 - 620 Kohms.
The manual says you have to remove the intake manifold to replace the KS. However, I think that a person with good dexterity and a 10mm ratcheting box wrench could replace the KS without disturbing the manifold.
Important note: the dealer can do a more thorough test with his CONSULT electronic tester. The resistance test described here is a useful but limited test. A Knock Sensor which fails this test is definitely bad. However, a KS which passes this test is not guaranteed to be good.
i think you should recet your ecu and check if you get same codes again
maxinout93
Oct 31, 2015 02:04 AM
maxima-junky
Oct 7, 2015 06:13 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
