I bought a THERMOSTAT
I've already read the how to in the stickies, but still have these questions.
I decided to change my thermostat because my car was taking a real long time to warm up. So I bought one from the dealership for about $20. I looked at it and I asked if there was a gasket. The parts guy said thatg these ones dont have a gasket, and just to use silicone.
So I need advice & tips on changing the thermostat. So since there is now thermostat gasket, what kind of gasket sealer do I use?? And do I just put it around the edge of the housing, or on the surface of the housing itself????? Any other tips/advice???
Yea there is a gasket, you can use regular silicone from an auto parts store to seal it up. Just let them know your doing a thermostat, they'll most likely give you a blue silicone... red is high heat, black is pretty much all around purpose and blue is for thermostats.
Ok thanks for all the advice guys. I called the dealership back and they said they had it in stock and it was like $5.50. I didnt feel like driving all the way back there.
So I went to 2 parts store and only one of them had the gasket. But it was a regular fell-pro gasket. So i bought it for $1, and also bought some water pump/thermostat gasket maker. I took out the old thermostat, (really easy compared to the 3rd gen, I dont know why they didnt think of the idea of attaching the thermostat to the housing before, its so much easier than trying to make the but needle thingy point up.)
anyways while I was taking it out I was kinda scared of the coolant going into the alternator since it is right underneath the t-stat, so I covered the alternator with a plastic bag. Then after I took off the t-stat, I realized that the original gasket was in good condition, so I cleaned it up, and used regular black RTV silicone on both sides of it to attach it to the block and the housing. And thats it, much easier than other cars. I didnt even drain the coolant, and only ~~1 qt. came out of the t-stat place on tha block.
Thanks for ALLLLLLLL the advice everyone...
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
aminus21
Sep 12, 2015 04:53 PM
Violator
Sep 9, 2015 10:14 AM
