Clutch hydrolytics gone?
Old Oct 1, 2004 | 08:38 AM
williamconor's Avatar
Over the past 36 hours my clutch pedal went from mushy to completely gone - no pressure (and no clutch!). The clutch itself was replaced recently and has worked great for the last five months.
Upon investigation, the c fluid reservoir was empty and I filled itback up, but when I pump the clutch pedal, I can't get ANY pressure up. The outside of the clutch master is dry, but the slave looks a little moist.
How bad do you think it is? I thought I would get some pressure back so I could bleed the line. Do I need to replace any parts first if I can't get the pressure up? Or should I get some leak dye and a black light and see what shows up?
Old Oct 1, 2004 | 10:05 AM
Zack342's Avatar
Hydraulics*
Old Oct 1, 2004 | 10:29 AM
SkinnyMax's Avatar
maxima no more
well you are losing a lot of fluid somewhere, shouldn't be too hard to spot. my guess is that it is the slave
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
