Changing the bulbs in the dash
Whats up guys I have a 95 maxima gxe and I was just wondering if I could switch the dash color where the speedometer is from the stock gxe to like a blue or red. Do i have to switch out the bulbs and is it worth it to do? Any directions on how if possible. Thanks also i heard that the bulb might be 194 are these hard to get in blue. Thanks guys
yer you can do it and if you do it right it is worth while. IF you are going to chnage the color of it youmight as well buy 194 led's off ebay, cause 194 blulbs will fade behind your dash. For the price you can get these bulbs you can get indiglo's. Check at the top of the forums for the How TO: sectio, and look thorgh those to see how to change the bulbs out. good luck
I've done this mod and yes, it is worth it to do.
I switched my stock bulbs with 4 LED-per bulb bulbs from superbrightleds.com. Pulling the gauge cluster out was a btich the first time, but it's worth it in the end.
Actually while I was in the gauge area, I switched from my stock black GXE gauges to white SE gauges, and threw some chrome gauge rings on for good measure, and I love it!
http://www.geocities.com/amixam69/nissan/dash/ from the how-to's to do this project...
you are getting spots with a incelucent bulbs? weird. yea i had blue in there before i got indiglos and they always faded to green within like 3 days. they suck. either do led's or indiglo's. it is weel worht it cause you will have to rip out all that **** again and put new bulbs in there.
Thanks guys I put regular bulbs in the dash but it looks like there is no difference. I need to get some led. I want them to look like electric blue. Thanks again guys. O by the way does a local auto parts store cary leds and does it make a difference which one?
I asked around my town when I was looking for LEDs, and I only got recommendations to get them online because they last FOREVER, so it wouldn't be profitable to sell replacements because they would sell so few bulbs.
If you don't want the "hot spots" that LEDs are known for making, order the "WLED-B Blue LED bulb with Wide Angle Viewing" from superbrightleds.com
is is better wo go with a white led rather than a 194 polarg. The polargs are good bulbs, but led's will give you a better more even all over color cause they never fade. before you put leds in sand them down quiet a bit so it spreads the light more and you won't have spots. i did a 01 altima in white and it was tight as all hell.
This isn't the best picture, kind of blurry, but you get the idea. I just bought 194 Red bulbs at Walmart. Goes from white to red, from red to white.
http://4drspeed.com/images/maxima/P1000155.JPG
LOT OF GOOD INFO in the FAQ and the HOW-To Stickies.
Here's the info you wanted
How To Change Gauge Bulbs -
also: http://www.richardjasaitis.com/MaximaDash.htm
Yep 2 Da Max, I've got a 96 like you and I did this little mod, and I love the results!
Yeah, if you get 194 bulbs from anywhere really (I recommend superbrightleds.com), you can just pull the 5 bulb slots out from the back of the gauge cluster, switch the bulbs (make sure the polarity is right by guess and check), and reinstall and you're all set!
mikeg75
Nov 30, 2015 05:12 PM
Kingofmaximas24
Nov 12, 2015 04:40 PM
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
