Question about Cefiro Headlights
Old Oct 1, 2004 | 06:20 PM
Nismo98's Avatar
Once the Cefiro headlights are installed, could you go back to original headlights or too much custom work is needed that the OEM lights will not be able to go back in. Also an aftermarket grill can be added with Cefiro's, right?
Andrei
Old Oct 1, 2004 | 08:44 PM
Nismo98's Avatar
TTT.
Andrei
Old Oct 2, 2004 | 10:06 PM
Chunger's Avatar
My other car is a Hybrid
Seeing that one of the original brackets is cut out and there is some trimming... somewhat difficult to return to stock... Keep the bracket pieces and you could probably reweld them in.
Dunno about aftermarket grills.
Old Oct 2, 2004 | 11:27 PM
Nismo98's Avatar
Andrei
Old Oct 3, 2004 | 12:00 AM
Saddles's Avatar
i have heard some people cut the bracket at the top and then just bend it down....so you could just bend it back up if you wanted to go back to stock. i dont see why a custom grill wouldnt fit...you might have to be creative with how you attach it...mines the stock grill and its zip tied and bolted in...but it should still physically fit i would think
Old Oct 3, 2004 | 12:06 AM
atpham89's Avatar
hey... you never know..... custom work can do wonders... hahaha... you can try using the plumbers tape and putting pieces together and try to form a bracket lol... or just get a sheet of metal welded on and drill the holes shrugs*
Old Oct 3, 2004 | 12:22 AM
aznprid972's Avatar
i thought you had to trim the fender alittle to fit the Cefiro headlights in. i dunno if u can undo that?
Old Oct 3, 2004 | 12:24 AM
|Bijan|'s Avatar
UCF Lexus
If you have to cut a bracket off, it will obviously need to be welded back on
atpham89's Avatar
well it's just that little nub holding the end of the corners in... i'm pretty sure you can mod it some how if you were to be cheap.... or spend the money to get a little piece or even buy a new fender... hahaha but anything can be done if you have the creativity i guess
AaronL
Nov 15, 2020 11:52 AM
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
