What spark plugs do you run?
Old Oct 1, 2004 | 07:51 PM
Coochie Coach's Avatar
What are good spark plug choices for a '97? Any clearly superior choices?
I understand platinum is a must, right?
Old Oct 1, 2004 | 07:55 PM
Wrightsfd's Avatar
Platinum is not a must, they last longer that is all. Copper is much cheaper and works as well, just change them more often. Every 30,000 versus 75,000+ for platinum.
http://vbxmaxima.8m.com/sparkplug.html
Old Oct 1, 2004 | 08:01 PM
THT's Avatar
THT
Throbbing member
NGK brand plugs are a must...platinum vs. copper depends on budget and willingness to change plugs more frequently.
~THT
Old Oct 1, 2004 | 08:09 PM
What's the difference between cold/standard/hot, and why the higher price for the cold ones?
Old Oct 1, 2004 | 08:12 PM
chuckie311's Avatar
im running DENSO Iridium
Old Oct 1, 2004 | 08:18 PM
davey6693's Avatar
I went with the NGK plats - set and forget.
Old Oct 2, 2004 | 02:07 PM
maximaman10's Avatar
I am running Bosch Platinum + 4
Old Oct 2, 2004 | 02:15 PM
ogparjay's Avatar
running ngk plats
Old Oct 2, 2004 | 03:13 PM
Flava_24/7's Avatar
Boosted Panda
NGK Platinums here.
Dont the coppers run a bit cooler then the platinums?
Bosch are crap compared to the NGKs
Old Oct 2, 2004 | 03:16 PM
GoalieKeg's Avatar
Running colder plugs is what FI guys normally do for a colder spark.
I run NGK Plats.
Old Oct 2, 2004 | 03:18 PM
Ant96GLE's Avatar
Originally Posted by FLAVOR247
NGK Platinums here.
Yes NGK coppers are 1 step colder, they're what the boosted and spraying guys are using.
I'm using coppers.
Old Oct 2, 2004 | 03:24 PM
1996blackmax's Avatar
I am running NKG platinums as well. There have been many people here who have had problems when running spark plugs other than the OEM ones (NGK), so just stick with those.
Old Oct 2, 2004 | 04:00 PM
PLUMMAXSE's Avatar
I'm running NGK coppers. 30k is long enough before I change them. Besides, I don't want any seized plugs messing up my block.
Old Oct 2, 2004 | 04:14 PM
My plugs came out pretty easily at 120k. When I installed my new platinums I used antiseize on them. I guess I'll find out in another 40k if I will have any issues.
Old Oct 2, 2004 | 04:38 PM
2 Da Max's Avatar
i use platinums, but i felt no difference, then again i did change plugs when my ks was bad
Old Oct 2, 2004 | 09:24 PM
joew's Avatar
colder? what does that mean?
I'm using coppers.
Old Oct 2, 2004 | 09:32 PM
fusionx21's Avatar
Running NGK Iridium
Old Oct 2, 2004 | 09:49 PM
Prophecy1's Avatar
I got an IDEA.. why dont you ask a question that hasnt been asked a million times and answered a million more..
If you read the stickies it recommends NGK.. Copper Or plats your choice
Proph
Old Oct 2, 2004 | 10:07 PM
joew's Avatar
be a bit more understanding comrade, some of us don't have access to the search function.
Proph
Old Oct 2, 2004 | 10:24 PM
Liquid_pjear's Avatar
Bad idea homes.
Old Oct 3, 2004 | 12:26 AM
atpham89's Avatar
the only difference are the pure platinums... which obviously is bank compared to the platinum plated.... haha...
Running..... NGK V-Powers (copps)
Old Oct 3, 2004 | 09:06 AM
Linksys_1's Avatar
I was checking the manual and it didn't show a gap for the plugs...does anyone know what gap to use or what gap do you use?
Old Oct 3, 2004 | 10:08 AM
2 Da Max's Avatar
plats are pre gapped checked the stickies for info on copper
Old Oct 3, 2004 | 10:28 AM
SuperFishstick's Avatar
NGK plats.. and would not consider anything else
Old Oct 3, 2004 | 10:55 AM
Julchen's Avatar
Nowhere in the stickies does anyone ever mention the gap coppers should be set to. I asked this question a couple weeks ago, and someone responded they should be gapped between .038" and .045" - can someone else confirm this for hte rest of us?
Greg
Old Oct 3, 2004 | 11:21 AM
atpham89's Avatar
.044, and you should always check the gap even though they are pre-gapped.
Old Oct 3, 2004 | 12:25 PM
maxima98vspec's Avatar
running NGK coppers, 1 step colder for the NX, gapped at .040
Old Oct 3, 2004 | 02:20 PM
MaximaSE96's Avatar
Maxima Owner
i run NGK Plats.......i had a bosch plat break in the head....the electrode broke off and shot into my fuel injector on my 91 maxima Bad stuff
Old Oct 3, 2004 | 03:42 PM
This is exactly why I told the other guy they were a bad idea they have a problem losing their electrodes.
Old Oct 3, 2004 | 07:59 PM
joew's Avatar
i read a thread 2 months ago where most maxers use copper. this thread mostly are plat user. now i guess it's just personal preference.
Old Oct 3, 2004 | 08:12 PM
Caracicatriz's Avatar
What was that?
I just put some bosch +4 in my maxima about a two months ago. Hopefully this doesn't happen to me. The car runs good though.
Old Oct 3, 2004 | 08:22 PM
atpham89's Avatar
They both function and perform the just about the same. The coppers usually last around 30k and platinums around 60k. As for platinums there are platinum plated/coated and pure platinum which obviously has a huge price difference. And there is the coppers 1 step colders which are more beneficial for boosted cars.
Spark Plug/ Part No./ Stock No./ Plug Gap
Standard/ BKR5ES-11/ 2382/ .044
V-Power/ BKR5E-11/ 6953/ .044
G-Power Platinum/ BKR5EGP/ 7090/ .044
Laser Platinum/ PFR5G-11/ 2647/ .044
OE Laser Iridium/ IFR5E11/ 7994/ .044
Iridium IX/ BKR5EIX-11/ 5464/ .044
- From my experience with Bosch +4, I had no problems with them. No loss in gas mileage or power. I had them in my car for about 50k. However, this is just for me and may be different on other users. What i'm trying to tell you is that it is not a 100% fact that Bosch will mess up your car, it varies.
just my .02
Old Oct 3, 2004 | 08:53 PM
joew's Avatar
atpham89, what does colder on copper mean?
Old Oct 3, 2004 | 09:05 PM
atpham89's Avatar
Boosting the car will increase the pressure in cylinders and temperature. Colder plugs will not burn as hot which results in lesser horsepower. But it will help reduce the chance of detonation, run higher levels of boost, and helps in reducing excess heat in combustion chamber.
Old Oct 3, 2004 | 09:27 PM
tpduke112's Avatar
I run NGK coppers, no complaints yet.
Old Oct 3, 2004 | 10:53 PM
SPiG's Avatar
SomePsychoGuy
http://maxmods.dyndns.org/index.php?MaximaSparkPlugs
Originally Posted by maxmods.dyndns.org
Only run NGK spark plugs in the Nissan engine. This point cannot be stressed enough. The engine and ignition system was designed with the internal resistance and exact parameters of NGK spark plugs in mind. Maybe some people have had some success stories running other brands, but others have lost 15hp, have lost gas mileage, have hesitation problems, or had to replace their whole engine, just by running non-NGK plugs. Don't say we didn't warn you ahead of time.
The gap distance for all these spark plugs is 1.1mm or .0433 inches, which is what the -11 in the model number stands for.
Old Oct 4, 2004 | 02:27 AM
NightRider's Avatar
I run Denso Iridiums gapped at .044. Great plugs.
Old Oct 4, 2004 | 07:32 AM
Stephen Max's Avatar
Everything you need to know about plugs:
http://www.ngksparkplugs.com/techinf...000&country=US
Old Oct 4, 2004 | 07:38 AM
I run NGK Plats.
A colder plug is one that is able to transfer heat from the plug to the cylinder head at a faster rate than a warmer plug. This is done to reduce combustion chamber temperatures in order to prevent detonation. Not necessary unless you are generating more than abut 50 extra hp over stock. I don't think the temperature of the spark itself is changed.
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
captchaos
Mar 15, 2016 12:18 PM
chernandez1278
Sep 16, 2015 01:18 PM
sdotcarter
Sep 2, 2015 09:53 PM
