Cruise Control and Dimmer LED QUESTION
Old Oct 2, 2004 | 03:54 PM
Max96LSU's Avatar
BLUE LED Project Complete w/ Pics (56k dont think about it)
I spent the day changing out the bulbs in my ACC to blue LEDS. So far it looks sweet. I'll post pick later tonight, but right now I'm having problems with the cruise and dimmer switches. If you are looking at the switch (cruise control), which is the negative LEAD? Any help would be great!
Old Oct 2, 2004 | 03:59 PM
97maxxx's Avatar
sry cant help ya but please post pics - i want to do this also
Old Oct 2, 2004 | 07:54 PM
Max96LSU's Avatar
Well I figured out which lead attaches to the LED, pics will be up tomorrow. Looks Awesome!
Old Oct 3, 2004 | 10:40 AM
Max96LSU's Avatar
Project is COMPLETE!!!
I'm finally done changing all the Bulbs to LEDs. Here are the ones I changed:
-Window Switches
-Security Light
-Ignition Key Ring
-Gauge Cluster
-Cruise Control
-Dimmer Switch
-Auto Climate Control
-Blue Clock Mod
-Blue ACC Display
-Blue BOSE Display
And now for the pics!!!!
Old Oct 3, 2004 | 10:42 AM
Max96LSU's Avatar
Old Oct 3, 2004 | 12:21 PM
RA030726's Avatar
I'm nutty for Nissans
what did you use for the blue bose, clock, and acc displays? I had red cellophane but it was too dim durring the day. Looks good, I need to finish up my LED stuff.........
Old Oct 3, 2004 | 08:09 PM
Max96LSU's Avatar
I used one layer of blue celophane and one layer of red celophane for the clock and ACC displays. For the BOSE HU, i used only one layer of blue celophane. it matches up quite well. During the day it's a little blurry but for the most part, I dont mind. I like the way it looks at night.
Old Oct 3, 2004 | 08:30 PM
blkhawk500's Avatar
i just changed my guage cluster to blue leds also, but I forgot to do my signal indicators. Did you change yours to blue, if so is it just a blub switch like the gauges or do i have to use celophane?
Old Oct 3, 2004 | 08:53 PM
Max96LSU's Avatar
uh man, i didn't think About changing the turn indicators to blue. I may have to look to see if I could replace the bulb or have to use blue celophane.
Old Sep 7, 2008 | 05:51 PM
maxprivate's Avatar
Black Lion
Way to bring back an old thread but did you guys figure which is the negative copper terminal on the cruise control switch? also the dimmer switch ?
Old Sep 7, 2008 | 10:56 PM
aznprid972's Avatar
I believe the ground would be Pin 4 on the M27 plug for the cruise control.
And Pin 3 on the M32 plug for the illumination.
Hope that helps.
Old Sep 8, 2008 | 04:12 AM
maxprivate's Avatar
Black Lion
Hope that helps.
cool thanks for the diagram... ill check it out and confirm.
Old Aug 7, 2009 | 01:10 PM
maxprivate's Avatar
Black Lion
Cruise Control Led
Can anyone Identify which is positive and which is neg for the cruise control Led on the right side of the swith? Accroding to the diagram terminal pin 5 and 6 on the M27 plug should be for the cruise control light. But when I bring 12v to it, it does't light up. I also tried bringing 12v to terminal pin 4 and 3 on the M27 plug for the ON light and that works fine but 5 and 6 doesn't seem to make the Cruise Control Led light up. Anyone done this can tell me what Im doing wrong?
Old Aug 7, 2009 | 08:49 PM
maxprivate's Avatar
Black Lion
I think I may have it figured out. Looking at the diagram with the M27 plug facing you the same way as in the diagram (pin side) 6 and 1 is what powers the led for Cruise Illumination light. I know that seems wierd because the diagram says 5 and 6 for Illumination (uness Im reading something wrong) but I tested it bringing 12v to 5 and 6 and nada no worky. I then tried + to pin 6 and - to pin 1 and the LED for the Cruise Control Illumination finally lit . Don't know why But now I'll just plug it in tomorrow and see if it will work. I'll post back with results.
Old Aug 9, 2009 | 08:47 AM
maxprivate's Avatar
Black Lion
plugged it in and it did not work something is wrong. Im just gona check for power at the plug in the car and try to narrow it down that way. I guess 6 and 1 doesnt power the Cruise Control light. Maybe it depends of the position of the switch but i tried moving it and nothing. Not event the ON light lit up. I feel like in the only one that cares about this. Anyone got this thing working? Come on! I know someone had to get this working.
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
jds22
Sep 4, 2015 01:52 PM
Johnny9595
Sep 3, 2015 05:18 AM
