car won't start after messing with speed sensor
Old Oct 2, 2004 | 04:27 PM
DFWmax's Avatar
hey all --
my friend and i were installing navigation systems in our maximas; my friend went and tried to install the speed sensing wire to the back of the instrument panel.
the navigation system diagnostics initially said the speed sensor was functioning ok, but then we drove around the block to test the navi system.
about 10 minutes into the drive, we stopped and turned off the car to restart the navi system. after that, the car wouldnt start.
we checked for ecu codes and got 1401 and 1402 codes, but there is no listing for those numbers. we also saw a 1102, but it only happened once; it only repeats 1401 and 1402.
have any of you seen this or have any idea of what we messed up?
thanks in advance...
dfwmax
Old Oct 5, 2004 | 02:24 PM
T.Maximus's Avatar
is the security light on? If so somehow you activated the engine immobilzer system and will have to get towed to a dealership to have them re-set the computer...
Old Oct 5, 2004 | 04:37 PM
cam_honestiam's Avatar
I would try a few things before towing:
1. Close all doors and lock with remote (if possible). If remote lock is not possible, lock them manually. Then unlock only the passenger front door with the key.
2. Unhook battery cables for 12 hours or more.
3. Reset ECU if unable to connect battery cables (see FAQs for procedure).
My car locked me out, and the dome light would flash at me when I tried to start. I assumed that the immobilizer had kicked on. After mixing and matching the above-mentioned procedures, I was able to start the car the next morning.
Old Oct 8, 2004 | 08:18 AM
DFWmax's Avatar
thanks guys --
it turns out that it was the immobilizer. the dealership said too many repeated starts/stops with the key can cause the security to kick in.
my friend is battling the dealership on this issue. he got charged $180 (somethere around that price) to get the keys/system re-synced. it isnt right that the system should/could lock you out when you have a legitimate key.
thanks again for your replies,
DFWmax
mrc00l88
Jan 25, 2024 01:14 PM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
