What exactly is clutch "slipping"
I think my clutch is slipping, but without a definite definition of slipping I'm not sure.. When I start the car, the car revs to 1.5k, I think that's normal.
My clutch's friction point is really far, is that normal for maximas? Other than this, I don't think anythgin else is abnormal. I was doing a hard launch yesterday, and the check engine came on for like 2 seconds, then went off and never saw it again.
Is my clutch slipping?
Thanks,
Dan
Thanks,
Dan
Originally Posted by SuperFishstick
thats beautifull.. what stage pressure plate u got? You got S/C so must be at least stage 2 right?
Turns out the ACT alone was too agressive and warped my aluminum flywheel. I wanted soemthing that would do 2 things:
1) Slip ever so slightly on engagement to prevent torque shock to the tranny.
2) not warp my flywheel.
This is the same setup that MardiGrasMax uses on his setup, and he launches at 6k RPM at the track with no issues. (Mardi ran an 11.9 on his SC, and is now even faster with his new Turbo).
Beautiful clutch.
Pretty agressive, but you get used to it.
Here's is the Pressure Plate:
www.clutchnet.com
Originally Posted by MaximaSE96
mmmmmmmmmmmmmmmmm 6 puk hmmmmmmmmmmmmmm...and ur clutch isnt slipping...DONT BUY ACT
Many people have them NA and mildly boosted and have no issues. Many people have had issues as well. It depends on who you tlak to.
My opinion - from my experience - they suck.
My clutch slips, and just as iansw noted, it is obvious.
I get in 3rd, 4th, or 5th and depress the accellerator and I get an RPM build, no accelleration, then it catches, I get a brief lurch, and then it repeats. I also have no "pull" in nearly any gear. 3000 RPM and above I am basically dead in the water. I do ALL granny shifting until this weekend when I get the new clutch.
Originally Posted by iansw
I got the Stage 1 Pressure Plate.
Beautiful clutch.
Beautiful clutch.
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
carlosvq30
Sep 26, 2015 09:44 AM
