Maxima Short Shifter cross-applications...
Old Oct 4, 2004 | 08:06 AM
phenryiv1's Avatar
Mod her. Ate her.
Will ANY Sentra/altima Srhort Throw Shifter STS work on the 4th gen, or only specific brands? Many reputible companies list the same part number for both applicatins, with B&M being one of them. Just wondering.
Old Oct 4, 2004 | 11:40 AM
MrEous's Avatar
^ Jeff™
I don't see why they wouldn't be interchangeable. Just as long as you are using the same applicable years. (i.e. newer Sentras/SpecVs have a different shifter linkage)
If you do try this then make sure the company you get it from has a good return policy...just in case.
Old Oct 4, 2004 | 12:48 PM
tomservo291's Avatar
check summitracing.com for specific part numbers, they list a part and all cars it works on rather then vice versa (in the application description field of it.)
i believe their b&m sts lists 4 or 5 cars it fits
Old Oct 4, 2004 | 01:43 PM
Terran's Avatar
It may not work. My B&M came with some plastic washer's which I believe would not be used on some applications and some copper inserts that I didn't use...In short, I wouldn't count on it working.
Old Oct 4, 2004 | 02:04 PM
MrEous's Avatar
^ Jeff™
Well...the extra copper parts you didn't use could be used on another Nissan that is listed with the same B&M STS Part #.
That's why you had extras.
When you received your B&M was it not in a sealed package and bearing the same Part # as listed on the website that shows it is used on Sentras and whatnot?
It saves B&M $$$ that way.
Old Oct 4, 2004 | 02:45 PM
Terran's Avatar
I know all that. That was my point. If a STS is made only for one of the cars that you would use the copper filler sleeve things with then it wouldn't fit the max.
Old Oct 4, 2004 | 06:18 PM
RA030726's Avatar
I'm nutty for Nissans
im pretty sure a B14 shifter is the same
Old Oct 4, 2004 | 10:25 PM
... did you get the sealed kit from B&M .. shrink wrapped plastic over a cardboard back, blue anodized base?
i didn't have any extra parts...
those copper inserts you mentioned, they were hollow cylinders no? I used them on mine. they fit inside the pivot ball that bolted to the change lever to make a secure fit.
i hope that if you didnt use those, you used something else... otherwise there is play in your system, i would think
Old Oct 4, 2004 | 10:41 PM
ManualMaxima's Avatar
5th Gen till she dies!
ity does matter, some shifters are different. the list is short but here it is:
-95-01 maxima
-86 - 89 stanza
-91 - 93 NX1600/2000
-91-96 sentra/200sx
criminalslang810
Aug 16, 2015 08:12 AM
doobadoo
Aug 15, 2015 06:43 PM
Trin1j23
Aug 12, 2015 08:31 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
