2nd at high rpm's
Old Oct 5, 2004 | 05:27 PM
Blue96Max's Avatar
2nd at high rpm's
2nd at high rpm's
ok when i take off on 1st and if im at high rpm's like 5500 or 6000 and i go to switch to 2nd it grinds! any1 no the reason why?
Old Oct 5, 2004 | 06:13 PM
Zach95SE's Avatar
Originally Posted by Blue96Max
2nd at high rpm's
Have you driven standard for a long time? If not then you just might not be pushin in the clutch all the way and im not tryin to be funny but I know on my Jeep when I first started I use to do it.
Old Oct 5, 2004 | 06:39 PM
MrPink's Avatar
How many miles are on the tranny? It sounds like a worn out synchro (i think they are brass on the maxima). Has the car had alot of differnt drivers? Sometimes that wears out synchros faster. Also how much freeplay do you have in your clutch pedal? Your soposed to have an inch of freeplay before you feel resistance in the clutch pedal. Also check your slave cylinder make sure the fluid is full
Old Oct 5, 2004 | 06:43 PM
Blue96Max's Avatar
where is my slave cylinder and i have been driven 5spd for 2 years now and the tranny has 146k on it
Old Oct 5, 2004 | 06:45 PM
Blue96Max's Avatar
how much is a synchro ?
thisisausername's Avatar
an inch of freeplay? I have like 2 1/2
Old Oct 5, 2004 | 07:04 PM
98SterlingMax's Avatar
Humble '06 TL Owner
Synchros dont cost much but getting to them (removing and disassembling transmission) does. They are replaced as part of a transmission rebuild.
Old Oct 5, 2004 | 07:09 PM
Blue96Max's Avatar
how about the slave cylinder ?
Old Oct 5, 2004 | 07:17 PM
Humble '06 TL Owner
Probably not a slave cylinder issue. If it is not leaking (you can tell if the master cylinder reservoir stays relatively full) then it is most likely a synchro problem.
Old Oct 6, 2004 | 12:26 PM
MrPink's Avatar
Im not 100%on this but your slave cylinder should be just in front or to the left of the master cylinder(looks like a small master). But if the clutch has alot of mi on it and the pedal has that much play you might just need a clutch
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
