Check Engine Light
Old Oct 6, 2004 | 02:16 PM
Ukranian6Banger's Avatar
Check Engine Light
i have a 95 gxe, and this morning my car di not want to star, it took me about 4 tries to start the engine, after it started, the car stalled and then when i restarted the engine the "check engine" light came up, could some tell me why that could have happend... the car has 92500miles, auto.
-Dima
Old Oct 6, 2004 | 02:18 PM
Ezekiel 25:17's Avatar
pull the code form your ecu and then look up what the code is.
Old Oct 6, 2004 | 02:22 PM
urmab's Avatar
pull the code its fairly easy, its probabaly a ks or a oxygen sensor that went
Old Oct 6, 2004 | 02:25 PM
ZeRo MaX's Avatar
can auto-parts or auto-zone pull it up for you? :-D
Old Oct 6, 2004 | 02:42 PM
slizan99's Avatar
why would you even say that? for one thing neither of those sensors would cause a hard start issue. the knock sensor doesn't even throw a CEL. Unless you know what you're talking about, don't put you .02 in.
As for the thread starter: Read the FAQ's at the top of the forum. these will tell you how to check your ECM for codes and also what the codes mean.
Old Oct 6, 2004 | 03:50 PM
Frank Fontaine's Avatar
Yeah, it seems sometimes that wrong advice is given so nonchalantly on this forum. I've never had a cold start issue, but I did have a hot start issue caused by the EVAP and boost sensor.
The thread starter's car is not high mileage, so it'd be curious to know what is causing the issue. My car has 96k and the EVAP went bad in the high 50's. Nothing since except the airbag lamp.
Old Oct 6, 2004 | 03:53 PM
minsbang's Avatar
Yes, for free. That is where I go to have my CEL checked out...
Old Oct 6, 2004 | 04:06 PM
MaximaTodd's Avatar
G
be sure to check your throttle body. mine was pretty dirty and it caused hard starts. after i cleaned it, no more problem.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
