Hard Starting Help!!!!!!1
Old Oct 6, 2004 | 07:15 PM
maxs4life's Avatar
I got a 95 max gle and its always gives me a hard time to start
i,ve changed all spark plugs, check all coils and put in a cai. i always used premium gas and i dont understand and the check engine light came on somebody told me that the cam postion sensor was bad could that be the problem . what can i do. how can i fix this
replace cam sensor or is there something else.
Old Oct 6, 2004 | 07:30 PM
MaxTJ's Avatar
Have you checked your battery? I replaced my battery, fuel filter, and my sparks plug and now it starts up great.
Old Oct 6, 2004 | 07:36 PM
maxs4life's Avatar
battery is fine and i change my fuel filter last week. spark plugs change too
still gives me a hard time.
Old Oct 6, 2004 | 07:37 PM
maxs4life's Avatar
sometimes when i reverse the car will just turn off
whats up with that
Old Oct 6, 2004 | 07:42 PM
njmodi's Avatar
Do I get a tax break?
1. Is your CEL still on? What code(s) has it stored? See the stickys for info. on retrieving the codes yourself.
2. Did you replace the fuel, and air filters, PCV valve, clean the throttle body and IACV?
3. Did you replace the engine coolant temp. sensor (ECTS)?
4. Is it ALWAYS hard to start (hot or cold) or only after its been sitting for a while?
5. Does it turn over at a normal rate, but just not "catch" - or it is sluggish while cranking too?
6. Finally, if the ECU is reporting the Camshaft position sensor (CmPS) error code, this part can be bought for around 60 bucks and replaced easily yourself. If the CmPS is faulty, it can indeed cause hard starting and eventually the car may not start at all.
Old Oct 6, 2004 | 08:02 PM
maxs4life's Avatar
what does all those codes mean
im new with all this
Old Oct 6, 2004 | 08:14 PM
njmodi's Avatar
Sounds like you need to read all the stickies at the top of the 4th Gen Forum. Meanwhile, if your CEL - aka. check-engine-light - aka - service engine soon light is lit, go to your local autozone and have them decipher what codes are stored - the car computer is trying to tell you something when that light stays lit.
Once you have the diagnosis from autozone, go to your favorite mechanic and have them fix it. Meanwhile keep reading and learning!
Cheers.
Old Oct 6, 2004 | 08:22 PM
maxs4life's Avatar
WEEEEEEEEEE
Old Oct 6, 2004 | 08:23 PM
maxs4life's Avatar
if a sensor is bad can you reset it so that it can work again
how about a cam ppstion sensor
and a knock sensor
or they have to just be replaced.
thanks for all your help.
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
