Turn Signal Problem...
For some reason, my turn signals decided to stop working. Here is what is going on:
Emergency blinkers do not work
Turn signals in dash do not flash
Blinkers in front and rear not working
However, if I use my remote to lock the car, the lights blink just fine. I checked all the fuses, and not one is burned out. Any help with this would be appreciated...it sucks driving in downtown Chicago with no turn signals!
Try checking the wiring for the hazard light button in the dash. The turn signals are wired through that button and won't work if the wiring is disconnected. I found that out the hard way when I drove my car after disassembling the dash to install audio gear and then driving the car with the dash still torn apart.
Could it be his flasher relay? Do you hear a clicking from right under your steering wheel when you use your remote to lock your car (you'll have do it from inside the car to hear it). I'm wondering if its the same relay that controls the flashing for the keyless as for the regular turn signals...
tarun900
19
12-20-2021 06:57 PM
06-06-2017 02:01 PM
RealityCheck
10-02-2015 06:34 PM
