Real Quick: Just need a how to.. change the rear brake pads
Old Oct 7, 2004 | 02:29 PM
XoPtOn's Avatar
all the links for the how to... change rear brakes dont work. Any1 know a link that works?
Old Oct 7, 2004 | 02:56 PM
njmodi's Avatar
Do I get a tax break?
Same as the fronts - except the caliper piston is screwed back into the caliper not compressed - this is a VERY important difference. Other than that its the same. Here is a link with details on the front:
http://www.motorvate.ca/mvp.php/300
Old Oct 7, 2004 | 03:21 PM
XoPtOn's Avatar
do u mean its easier or harder?
Old Oct 7, 2004 | 03:58 PM
njmodi's Avatar
Not easier or harder - just different. Only that step is different... i.e. to make room for the new pads you will have to retract the piston into the caliper. On the front the piston is just pushed back into the caliper, on the rears, the piston has to be screwed back into the piston - do NOT push/force it back in.
Old Oct 7, 2004 | 04:17 PM
JPMax's Avatar
What's next!?..
The rear pistons require a special little tool you can pick up at Autozone. It looks like a little square cube that fits over the center of the caliper and lets you turn it forward or back as needed. Doesn't cost much.
Some people use some pliers to try turning the caliper but if it hasn't been moved in a long time, it's gonna be really hard to turn.
Old Oct 7, 2004 | 05:25 PM
SkinnyMax's Avatar
maxima no more
just to clarify before the question is asked, turn the piston clockwise
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
