Throttle boddy cleaning question
Old Oct 7, 2004 | 09:04 PM
amulla01's Avatar
I bought the throttle body cleaner spray and cleaned my throttle boddy with it as directed by motorvate.ca. But I read the instructions on the back of the can and it says that I have to turn on the engine and push the valve in throttle body inside and spray the cleaner until used all of it up... This spray is highly flamable, is it wise to follow their instructions and start the engine with the boddy wide open and push it manually in and spray the can in?
Thank you all in advance.
Old Oct 7, 2004 | 09:10 PM
Ant96GLE's Avatar
Well first off, if you take the MAF portion of the intake off the intake the car will turn off.
What I have done is take the intake with MAF off and spray in there, take a rag and clean as deep in there as I can and open up the throttle body.
Then turn on the car and have someone manually hold the intake with MAF on the intake so the car doesnt turn off. Remember the car will be hard to start because of the fluid in there. Then slowly take off the intake until you can spray inside of the intake without the car turning off.
Old Oct 7, 2004 | 09:30 PM
amulla01's Avatar
So its not enough to clean out all the dirt sitting just on corner of the butterfly plate of the throttle body (without starting the engine)?
Old Oct 7, 2004 | 09:49 PM
Ant96GLE's Avatar
Sure it is and you'll get alot of crud from where the butterfly plate is at, but just to get all up in there with the engine on, thats the way to go.
Old Oct 7, 2004 | 09:55 PM
amulla01's Avatar
Okay thanks bro, hey we live close to each other... you're on the other side of the bridge
Old Oct 7, 2004 | 11:31 PM
Analog-SE's Avatar
Do you really have to leave the car on during the cleaning. With my car off, i was able to clean in front of the plate, and get it open and clean past it too.
Old Oct 8, 2004 | 08:55 AM
UncleMax98's Avatar
I think the main benefit of cleaning the throttle body is to remove the gunk between the butterfly plate and the bottom of the throttle body. So the idle is smooth and the gas pedal don't get sticky. Cleaning every 30K or so is good enough for me.
You can try to clean deeper inside the intake and get more dirt out, but there are dirt through out the intake manifold. What's the point of removing 10% of the dirt when the majority is still in there. The benefit is just not worth the extra work. If you still want to get it (intake) clean, a Seafoam treatment may be more effective.
Old Oct 8, 2004 | 09:43 AM
my99maxisnice's Avatar
A seafoam application doesn't clean the throttle body
boomerbrian
Sep 4, 2015 08:25 AM
crazyespn
Sep 3, 2015 01:30 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
iflexsteel
Sep 2, 2015 08:04 AM
