stripped NUTZ!!! OMG
I just got my y-pipe in yesterday and i went to install it, and i was able to get all the nuts broken loose EXCEPT for one which was being stubborn and we ended up stipping it. Is there anything i can do to get it off without having to take it to a shop? PLZ help
Its probably so frozen that you'll need a torch to try and heat it up. Get a small cylinder of MAPP gas from Home Depot along with a nozzle.
If that doesn't work, then you'll need to take it into a shop and have them torch it off with an acytelene torch.
Originally Posted by GLEtotehMAX
yea i used a rust penatrating spray, but i guess it didnt help much for that one bolt
any other ideas?
any other ideas?
same thing happened to me and in the process we crimped the nut on with vise grips trying to get it off. torch did nothing. so what i did was very carefully grind a side off the nut with a small cut off wheel on a dremmel tool, carefull that you dotn go too deep and hit the threads of the stud. once i got it down pretty far i hit it once with an air hammer and voila.
if it's the bolt under the rear header, you should have use pivot socket to help you remove it.
if it's the bolt on the cat, you should have use a breaker bar to help you remove it.
dude, if you are like me and hate taking your car to the shop, go to sears and pick one of these, http://www.sears.com/sr/javasr/produ...id=00952160000
good luck!!
good luck!!
rbarnes
Dec 31, 2015 06:29 PM
RealityCheck
Oct 2, 2015 06:34 PM
