Stillen Camber Plates (/w Sprint springs). from GCs?
Old Oct 11, 2004 | 05:23 AM
DonSupreme's Avatar
Question guys.
I just purchased some sprint springs. I tried to install them Saturday but failed because I don't have the stock strut mounts.
I instead have stillen camber plates.
I thought for a 2 inch drop a camber correction kit was suggested.
What should I do guys? Do I need to purchase stock top strut mounts or is there some trick?
P.S. I am coming from Ground controls.
Old Oct 11, 2004 | 09:38 AM
DonSupreme's Avatar
Anyone out there with advice on how I can accomplish this suspension install?
Old Oct 11, 2004 | 07:58 PM
DonSupreme's Avatar
Bump? Someone must know...
Old Oct 11, 2004 | 09:20 PM
1MAX2NV's Avatar
You need those strut mounts.
Old Oct 12, 2004 | 06:12 AM
DonSupreme's Avatar
Thanks for the response. Can the camber plates and the mounts be combined? Additionally, where can I buy the mounts?
Old Oct 12, 2004 | 07:53 AM
ny96max's Avatar
you wont need camber plates... My mechanic was able to get me into factory spec easily with the sprint drop and still have room for further adjustment. I wasted $60 on eibach cameber bolts for no reason too
Ant
Old Oct 12, 2004 | 08:16 AM
1MAX2NV's Avatar
I don't remember the technical term for the two OEM parts that the camber plate replaces. It's the small black round piece with a large hole in the middle and the brass color piece with the 3 studs on it. Anyway, it needs to look like this. Maybe I'm getting strut mount and insulator confused...
Old Oct 12, 2004 | 10:18 AM
ny96max's Avatar
those are the stock pieces you will need. The top one is call the strut mount and the bottom half i have no idea. Just go to Nissan and order them, they are very inexpensive.
Ant
Old Oct 12, 2004 | 10:36 AM
DonSupreme's Avatar
A picture is worth a thousand words. Thank you, now all I need to do is find two of these. Those bolts going through what I am calling the mount and the camber plates, look like something I will have to source too.
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
