squeeky noise in right front passenger tire? rotars? brake?
Old Oct 12, 2004 | 06:30 PM
FishyMan's Avatar
hello, i notice a high pitch squeeel, squeek, and sound when ever i brake, and it is erally loud when its almost to a complete stop, not loud loud, but a noticeable soudn even w/ a/c on.
i also do hear a slight pitch sound comring from the passeger front right tire, as if something is being scratched while driving, not even pressing the brakes.
could this be the braking ssyterm?
what can i do? thanks..
Old Oct 12, 2004 | 07:23 PM
Wrightsfd's Avatar
Take the front pads off and apply a little Stop Squeak to the back of them.
Stop Squeak is about $3.99 from any auto parts store.
Here is how to get the pads off, it is easy: http://www.motorvate.ca/mvp.php/300
Old Oct 12, 2004 | 07:38 PM
amulla01's Avatar
i also got the squeak from right or left wheel when i dont press the brake... when i m reversing and i press on the brake my brakes squeaks like crazy... maximas got the worst braking system
Old Oct 12, 2004 | 07:48 PM
FishyMan's Avatar
so is it the pads? i hope its not somethign major... i mean if the sound only came when i pressed the brakes
cuz the pads scratch? or rubs while i am driving?? i am highly inclined to believe that since it makes sound even w/o pressing brake, but w/ brake it is jsut louder..
anyhow thanks. i will give it a try.. boy i just wish i could search.... trying to find out teh 'jack points' ... the stands i have, i think they may ruin the jack points. i actually posted about how to jack the car from the front w/ the aftermarket jacks, and use the jack stand... maybe i should bump it up... my stands dont' ahve the wedge ..
Old Oct 12, 2004 | 08:04 PM
Wrightsfd's Avatar
I am willing to bet it is just your pads. The pads stay in contact with the rotor all the time, they just have pressure when you press the brake pedal. The squeak could be heard all the time on my car too. I took all the pads off, filed the rough edges, applied stop squeak and now have NO noise.
There are small cut outs on the bottom of the car that show you where the jack points are. Use these points only to raise the car.
Old Oct 12, 2004 | 08:37 PM
FishyMan's Avatar
okay thanks i will give it a shot.... my stands dont have the wedge, so i have to get the adapter thing..dont wanan ruin the points.
Old Oct 12, 2004 | 09:51 PM
goodhead's Avatar
u can jack up your car and put the stands near the points it would be fine to, just make sure it wont fall, i usually try to shake the car befoer i go under there
Old Feb 23, 2005 | 06:54 PM
FishyMan's Avatar
what compounds do i need for NEW PADS or rotars or grease?
thanks..
i d k if i should clean out the brake components, i dont' have a clamp for the piston to push the air back out..
carguy96
20
Feb 6, 2021 06:21 AM
spidgeon
Aug 24, 2015 11:14 AM
george__
Aug 18, 2015 07:06 PM
follyburr
Aug 7, 2015 09:50 PM
