When do Coil pack usually go bad?
Old Oct 12, 2004 | 07:53 PM
AsthmaMax11's Avatar
When do coil packs usually go bad and how would you be able to tell?
Thank you
Bruce
Old Oct 12, 2004 | 07:56 PM
njmodi's Avatar
Do I get a tax break?
No set failure time. Symptoms are typically poor performance (butt-dyno) and intermittent hesitation.. might be other tell-tale signs.. but those are the most common.... sometimes the improper ignition is detected by the ECU an the CEL is set.. (but not always).
Old Oct 12, 2004 | 09:47 PM
could anyone give an estimate on how much to replace the coil packs?
it reminds me of the damn KS.
njmodi- thank you for the informative reply!!
Old Oct 12, 2004 | 09:53 PM
I30tMikeD's Avatar
You could go to the dealer and buy them, replacing all six will run you about $600. I bought one at full dealer price once for $93 each...returned it later.
Or you could find out which one(s) are causing you problems and find some used ones in the For Sale forum and only spend about $20 each. Or you could keep an eye out on ebay where they sometimes sell for $200 for all six new.
Old Oct 13, 2004 | 06:41 AM
njmodi's Avatar
You can actually get new coils for 60-70 bucks a piece from jrnissanparts.com - even less with the "maxima" promo code... so the total cost is more like 360-400 for all 6... a batch of the 99 model year are prone to premature coil failure. If you have a 99 it might be best for you to replace all 6 coils with the updated type. I can't remember off hand whether the Hanshin or Mitsubishi coils are better (or if there even is a difference).
Old Oct 15, 2004 | 09:55 PM
First of all, thank you for all your help. It's guys like you that put up with fussy people like me that make the world go round!! BUT, what did you mean by "intermittent hesitation"?
Yeh I got with an .org member today who can check the ?OHMs voltage? to see if they are bad or not and he also offered to give me some used ones he had laying around!
How is your car running after having them replaced?
BTW, after reading your post about just replacing your coil packs made me think about getting mine checked.....
Old Oct 15, 2004 | 10:29 PM
I30tMikeD's Avatar
Never replaced mine.
Old Oct 16, 2004 | 03:00 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
intermittent hesitation is when your car feels jerky. car wants to go back and forth without touching the accelerator of brake pedal.
Old Oct 16, 2004 | 08:40 PM
What was it that you did with them?
Old Oct 16, 2004 | 09:14 PM
Guinader's Avatar
ok, this is weird.
I nevere had this hesitaion problem until I did my compresion a few days ago. now when I stop accel. the car jerks a little.
do you think I place the coils in a different orther might have done the possible damage?
Old Oct 16, 2004 | 09:53 PM
I30tMikeD's Avatar
When? Do you mean in regards to the post in this thread. I had one that was acting up on me, I bought a new one at the dealer and then the car stoped acting up so I returned the coil pack and all was good.
Old Oct 16, 2004 | 10:02 PM
ManualMaxima's Avatar
5th Gen till she dies!
i do not know hw to find which one is bad, but if you do find out, i will see what i can do. i might be able to get you some off a used max and you can have the free. but let me know sometime.
do you have any of your old motors? i need a new oil pan cause mine is cracked or something.
Old Oct 16, 2004 | 10:41 PM
f550maranello2's Avatar
Originally Posted by Guinader
ok, this is weird.
Man i got the same problem in my car, i get off the gas and it jerks, then when i try to accelerate a lof of times the rpms will go up like normal then drop right down, if you figure it out let me know aight man.
Old Oct 17, 2004 | 09:27 PM
ok nevermind me, I must have completely misunderstood a post...I just knew that you had been doing alot of troubleshooting to see what was up with your dyno. Basically, I get really paranoid about my car since SO many things have been wrong with it.
Old Oct 17, 2004 | 09:28 PM
Hey I appreciate that man. I believe my old motor should still be at the dealership. I'll PM Jake...
jmlee44
Oct 2, 2022 02:13 PM
chisam14
Nov 6, 2018 08:56 PM
Andy29
Sep 29, 2015 05:32 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
