I wanna get down there. put my hand all over her and make her perform like a tiger
Old Oct 13, 2004 | 08:29 AM
maxcooldc's Avatar
i will be changing my rear suspension this weekend, i have been reading its a easy job that can be done at home. I just wanted some tips or a write up about doing the job ( i only have the hyans manuel). I know the manuel usually assume certain stuff ( i had a problem when i used it to change my brake pads). so any tips to make the job easier would be great.
Old Oct 13, 2004 | 09:13 AM
CaLSoNiC
Just make sure you remember EXACTLY how everything goes before you take it apart. Especially the rear bushings and stuff. Other than that, its a breeze, just time consuming.
Old Oct 13, 2004 | 09:16 AM
mzmtg's Avatar
Minister of Silly Walks
Order some new rear strut mounts from me while you're at it
Old Oct 13, 2004 | 09:51 AM
I30tMikeD's Avatar
I believe you can find a write up in the FAQ's.
like posted above, when you disassemble the strut from the spring line all the parts out in the ground in the order they need to be put back.
Make sure you have the front strut mounts faceing the correct way. You might want to mark the orentation of which side needs to be out before removing the spring.
When putting the strut/spring assembly back in, loosely bolt up the top first then bolt the bottom to the steering knuckle. Use the play in the lower control arm to line things up.
If your OEM spring isolators are torn to hell, either get new ones or make something that will work.
Old Oct 13, 2004 | 10:29 AM
erty67's Avatar
Decal Specialist
once you get done with the install, try to get out more
Old Oct 14, 2004 | 09:40 AM
maxcooldc's Avatar
cool but i was mainly asking about the rear strut. the front will have to wait for the moment as for going out. with all the girls lined up infront of my house theres bearly time to go out after each screw
Ohh thats the door bell.
duty calls
Old Oct 14, 2004 | 12:49 PM
JetBlackMax83's Avatar
i have suspension envy i want my tiko's!!!
Old Oct 14, 2004 | 12:53 PM
mzmtg's Avatar
tiko's ?????
Old Oct 14, 2004 | 12:56 PM
my99maxisnice's Avatar
Originally Posted by mzmtg
tiko's ?????
Yeah they're a new brand just out. What a noob.
MaximaDrvr
Aug 19, 2015 08:20 PM
Trin1j23
Aug 12, 2015 08:31 PM
09maxshawn11
Aug 9, 2015 01:13 PM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
