Where Is my TPS sensor located?
Yes, look at the mechanism that your throttle cables are connected to, there is a rod that goes from that straight through your TB and into the TPS. Now if you are considering changint this, be forewarned, it is more somplicated than just swapping it out.
ok, how is it more complicated? Also i just got back from autozone (picked up tps) and the one they gave me (that was suppose to be for my car) has two inputs and my current one has only one, they gave me the wrong part!
Some maxima's use a TPS and a WOT sensor. Some just use a TPS sensor. I would try and get the right one, but I bet you can use the one with two and just hook up the one you need. It should work fine.
Originally Posted by CarbonDreams95
damn... and how much is that gonna cost me?
I would suggest picking up a haynes manual as well, they are like $10 at any auto parts store. There will be easy instructions on how to set the TPS sensor.
appreciate it, any suggestions on where to go to get a multimeter
Make sure you get one with a wide rang of setting. My mistake was not getting one that read high enough ohm's to check my knock sensor
