Outer CV Joint worn out
Old Oct 14, 2004 | 03:41 PM
blaze0ne
I've finally figured out what the noise is when i turn the wheel; its the outer cv joint.
this site explains it perfectly:
Continues "clicking" sounds on sharp turns usually indicates a worn outer joint.
Usually the sound is loudest on the joint opposite of the turning direction.
i wanted to know how much it will cost to replace/fix the joint.
i wont be doing the work myself so i'm assuming labor is the biggest cost.
also would it be better to buy the parts online and bring it to a mechanic to install or have him get the parts?
thanx
Old Oct 14, 2004 | 03:50 PM
NmexMAX's Avatar
dot dot dot ...
160 w/ labor.
Old Oct 14, 2004 | 06:50 PM
kraimer21's Avatar
It's going to cost you the same either you buy your parts and bring it to the guy to do or just go to him "empty-handed".
here's a great write-up on how to do this yourself. I was going to do this on my mazda 626, and the boots cost me i think $12 a piece but I ended up bringing it to my mechanic for help because I couldn't get that huge bolt in the center loose. If you go to a mechanic its around $150.
Where in Brooklyn are you?
Old Oct 18, 2004 | 03:13 PM
blaze0ne
i'm in sheepshead
can you post a link to the write up?
Old Oct 18, 2004 | 03:14 PM
s0ber's Avatar
I replaced the with a friend.. its not hard... $60 total.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
londonflu
Sep 19, 2015 02:33 PM
Bonka
Sep 14, 2015 11:18 PM
DBear
Sep 14, 2015 08:33 PM
