How to access rear adjustable shocks?
Old Oct 15, 2004 | 09:33 PM
haysdb's Avatar
Any clever ideas for how to allow access to the tops of the rear shocks? I'd like to be able to adjust my rear Illumina shocks without having to remove the side panels, which is a pain because I have to remove a subwoofer, which is bolted through the floor of the trunk. The obvious answer is "cut holes", and that's fine, but I'll want something to cover the holes, to make the trunk look "finished".
Old Oct 16, 2004 | 12:34 AM
Maximeltman's Avatar
i dunno man
i just bend the **** out of the panels
and yea i got 2 treo subs in the way, but whateva!
________
Vaporizerinfo.com
Old Oct 16, 2004 | 01:05 AM
haysdb's Avatar
I have two amplifiers mounted up against the back seat, and a JL Stealthbox on the left side that's bolted in place, so bending the panels out of the way isn't a convenient option.
Old Oct 16, 2004 | 06:26 AM
njmaxseltd's Avatar
Your audio setup is preventing you from accessing the tops of the shocks.
Either reconfigure your trunk so you can get access to them or just set them and forget them.
You have two choices, pick one and be done with it.
Old Oct 16, 2004 | 06:42 AM
haysdb's Avatar
Reconfiguring the amps and sub is not an option. The JL Stealthbox is designed to fit in one place and one place only, and there isn't a better place for the amps.
I believe I have a third option, the one I suggested initially (cutting holes in the "carpets"), I am just hoping that someone else has done it and I can benefit from their experience.
It's not that big of a deal, as I am pretty happy with 2/2, but if I can soften up the rear anti-sway bar some, then I might want to go to 3/3. That just means leaving my trunk in pieces until I get the suspension tuned the way I want it.
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
