Koni Bumpstops
Old Oct 15, 2004 | 11:07 PM
G20Flyer's Avatar
Koni Bumpstops
Anyone who has used them...
For the fronts...do you put the pointy side Up or Down?
Same question for the backs???
This is on an illumina setup.
Old Oct 16, 2004 | 06:27 AM
njmaxseltd's Avatar
Pointy side down.
Old Oct 16, 2004 | 06:36 PM
Terran's Avatar
I've never heard of koni bumpstops. Does somebody have a link? Are they shortened like the KYB dustboot/bumpstop?
Old Oct 16, 2004 | 07:09 PM
G20Flyer's Avatar
Goto: http://www.motivational.net/ then click products -> Koni Bump Rubbers
Old Oct 16, 2004 | 07:19 PM
Terran's Avatar
So these would replace the stock bumpstops? What is their advantage?
Old Oct 16, 2004 | 07:30 PM
G20Flyer's Avatar
They are not hollow like the factory ones. If you hit the bumpstops they provide a gradual impact which allows for a better ride, especially on the lowered rides with less height.
I added those on to my Illumina setup as well as the Motivational rear mounts that give an extra inch of suspension travel.
Old Oct 16, 2004 | 07:46 PM
Terran's Avatar
So did you get them in? Have you noticed a big difference?
Old Oct 16, 2004 | 07:58 PM
G20Flyer's Avatar
Yah i got them in. I think the illuminas have done their job of not even bottoming out at all. I dont think Ive hit the bumpstops yet. If so...its not bad at all.
I remembered them from a friend when I had a G20 and he used them on his G because of they're "soft but performance-like" qualities.
Old Oct 17, 2004 | 07:27 PM
Mark97SE's Avatar
If I remember correctly the Koni's are just the bumpstop while the stock/aftermarket ones are bellows/bumpstop.
Is there any way to use these Koni bumpstops with the stock "bellows"(ie, cut off bumpstop portion) in order to help keep crud off the strut rods?
Old Oct 17, 2004 | 07:36 PM
G20Flyer's Avatar
Uhm you should be able to...I just bought some cheap *** $6 dust boots that have no bumpstop and they fit right over the konis
Matt93SE
May 24, 2019 02:58 PM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Gotrice4
Nov 4, 2000 09:48 PM
Keven97SE
Sep 7, 2000 07:56 PM
