6x9 Speakers in rear.
Old Oct 18, 2004 | 12:29 PM
killer2239's Avatar
Is it easy to fit 6x9 speakers in placement of the rear? Im looking at getting a 97 Maxima in the next month or 2.
Old Oct 18, 2004 | 12:32 PM
bigx323's Avatar
u'd have to cut a bigger whole in there
Old Oct 18, 2004 | 12:42 PM
1FSTMAX's Avatar
6x9's are old school... get a good set of 6.5" components instead..
Old Oct 18, 2004 | 12:44 PM
95BLKMAX's Avatar
Time to bust out the die cutter and air compressor *tim allen growl*. Naw j/k, dremel will do just fine, it's just not as fun, hehehe. I'm hoping to do the same sometime around January/February. I need tog et rid of my stock rattlers. Good luck. BTW, when you buy a pair of speakers, 95% of the time they come with a template for you to make the necesary triming to fit them flush. I know you have to cut the rear deck (obviously), I believe u also have to widen the opening on the frame underneath, since the magnet and the wires' hookups might not clear the opening.
Old Oct 18, 2004 | 01:23 PM
Tyrexx's Avatar
I have Infinity 6X9s and they sound better than stock, I bet the $250 infinity component speakers sound a little better but when I did my install I already had these 6X9s and I wanted more bass without adding subs right away. (before subs)
Old Oct 18, 2004 | 02:17 PM
killer2239's Avatar
I would get some of the best 6x9's they make. id take out my headunit in my car now, retails for 600 brand new. But i have a good amp to push the 6x9's, its a 75rms per channel. MY current setup in the car i have now, is 2 rockford fosgate 12" HX2, 1000rms amp, pounds harder than ****, and only turned 1/2 way up. But i dont want all the weight anymore and good 6x9's taht are powered by amp will sound pretty damn good.
Old Oct 18, 2004 | 05:08 PM
Guinader's Avatar
ok, so where would the write up on doing the 6x9 from a 6.5 opening.
I bought at ebay a set of bose 6x9s and only realized after I bought them.
can a car shop do it for you? (I mean I leave the speaker area clean down to the metal part, and ask them.... "cut the s**t out for me! please."
Old Oct 18, 2004 | 05:31 PM
lexx426's Avatar
thats pretty interesting, i would like to put my new 6.5's from the back to the front, and get some 6/9's in the back, somebody do a write up and tell how much it was...
Old Oct 18, 2004 | 07:40 PM
Max Noob's Avatar
all you have to do is cut a hole big enough. use the stencil that comes in the box with the 6x9. im thinking a dremel with a good bit, goggles, and a drill is all you need. use the stencil to draw a hold, cut it anyway you can, protect your eyes with the goggles. drill the new screw holes. try not to cut any wires along the way. good to go.
i agree with just using good component 6.5 you can get infinity kappa component system for about 130 on ebay, or even the reference series for like 90.
Old Oct 18, 2004 | 09:45 PM
Keyser Skoze's Avatar
You know what, i wish there were speakers on the doors also. One thing i miss about my VW, d@mn thing had speakers everywhere. That car sounded great... Too bad its a piece of $hit!
Old Oct 18, 2004 | 09:54 PM
tomservo291's Avatar
I did my rear deck 6x9's about 2 months ago with a dremmel. Took me 5 hours...
Gotta remove the bottom/back of the rear seats, remove the rear decklid without breaking the cheapass cardboard in half. Remove the 6.5's, use the template that comes with the speakers (the inner edge of course!)
What I did was used a ruler/tape measure before hand and got it all marked up with chalk with straight lines going across the deck lengthwise, then front/back straight through where I wanted them. I folted the template in half both directions to find the exact middle point and marked them, and lined up those points with my chalk lines. This ensured a square fit (if you skew them, the holes wont lineup with the holes you will have after cutting out the grills.
Cutting them out with a dremmel was a PAIN IN THE ***! Cutting a fairly sharp circle while performing contortionist like positions frequently resulted in me breaking metal cutting discs; i think I broke 3 and wore down 3 more to nothing.
NOTE: BE SURE TO COVER UP YOUR REAR WINDOW!
There is a sound deadening/padding ontop of the sheetmetal on the rear decklid, when the hot bits touch it it pretty much flings it everywhere and kinda melts it onto anything it touches. I'm just glad i was able to get it off my rear window without harming my defroster lines.
After cutting, you gotta drill the holes. Easy enough. So, most of the grunt work is done at this point, or so you think. I had a hell of a time being very careful while cutting up my rear deck fabric/cardboard piece to get it to sit in the right spot. Then it was 10x harder to get the screws through it and through the speaker into the hole in the deck. (My setup requires the screw to come down from ontop of the grill rim.)
Major PITA! But it was worth the effort imo. Sorry no pics right now.
Old Oct 22, 2004 | 12:52 PM
Guinader's Avatar
thanks,tomservo291.
I will probably do this in about one month. (will try to get some pics to show the work.)
Old Oct 22, 2004 | 01:09 PM
mendon99's Avatar
tastey wheat
i put 6x9 kappas in my car, dont do it, its so incredibly not worth it, just a huge pain in the a$$.. just sell them to someone and get 6.5's.
Old Oct 22, 2004 | 01:10 PM
Sprint's Avatar
you guys need to stop being cheap and buy a sub. You can't get real bass from a 6x9 it may sound like bass to you but its mid-bass..
Old Oct 22, 2004 | 01:12 PM
mendon99's Avatar
tastey wheat
BTW, heres some shots
Old Oct 22, 2004 | 01:17 PM
Guinader's Avatar
well mine are bose system, and I bought for $30 on ebay a set of 6x9 bose.
reason: my 6.5 have blown.
BTW I have all the stuff for the Sub, I just need Box now.
Old Oct 22, 2004 | 04:11 PM
Tyrexx's Avatar
Here's my pics, This was before tint. + I do have subs as well.
Old Oct 26, 2004 | 06:41 PM
sterlingmaxima's Avatar
6x9 sound like garbage to much base not enough treible 6.5 all the way.
Old Oct 26, 2004 | 08:52 PM
naijai's Avatar
i have 6x9 in my rear but i didnt cut anything used some wood to mount it to the rear deck and man does it sound awesome
Mar 12, 2020 12:06 AM
magiconthetire
Oct 26, 2015 09:03 PM
Excalibur23
Oct 13, 2015 04:33 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
