Door Ajar Sound
Old Oct 18, 2004 | 06:03 PM
sachmo12345
Door Ajar Sound
is there a way that i can just cut a wire and rid myself of that noise
Old Oct 18, 2004 | 06:16 PM
Ladzio's Avatar
Yes.
10 chars..
Old Oct 18, 2004 | 06:19 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
its located under the steer wheel pannel, where the fuese box and all is, just take that pannel off you see the white box, and you can disconnect the door ajar anoying sound.
Old Oct 18, 2004 | 06:20 PM
aznprid972's Avatar
the little buzzer is behind the driver kick pannel. remove it by 2 phillip screws and you can unplug the little white buzzer.
Old Oct 18, 2004 | 06:27 PM
sachmo12345
thanks a lot
Old Oct 18, 2004 | 06:52 PM
Magikone69's Avatar
i h8 that buzzer noise. mine is off now, but anyway we can put in a new chime. i kinda like the one from the old mitsubishi, its kinda nostalgic(sp?) for me since its what i learned how to drive with, mitsu galant.
Old Oct 18, 2004 | 07:32 PM
mendon99's Avatar
tastey wheat
ha i learned on a mitsu galant too
Old Oct 18, 2004 | 08:18 PM
MDeezy's Avatar
that buzzer can be anoying but it has saved me from forgetting my lights on many times, I gues you guess are better at remember to make sure all light are off but man sometime I maybe in a rush and it just slips my mind.
Old Oct 18, 2004 | 08:21 PM
iansw's Avatar
I disconnected mine because my alarm goes BOOP BOOP if I leave my lights on anyway.
Kinda embarassing because it's loud as hell. Made people at the gas pumps jump a couple of times....lol
Old Oct 19, 2004 | 10:24 AM
madmega's Avatar
when i bought my car it didnt do the door ajar thing.. i didnt mind until one day i left my lights on and didnt realize and i come out to a dead battery... so i eventually found out that its because the buzzer isnt connected, when i did go to connect it, i found the box but i dont know where the hell the wire / wiring harness that goes to it is.. if anyone know where the wire leads to or what it looks like, please let me know
Old Oct 19, 2004 | 12:45 PM
Entropy's Avatar
It is just an on/off connector? Like two wires... or is it a bunch of wires where you could figure out which wire does the "door ajar" noise and the one that does the "lights on" noise?
If you can't do it that way, you could just disconnest the switch at the base of the door frame (or hard wire it so it is always closed, whichever is necessary) - which should cut the door noise, but not the light noise.
Unless the light noise depends on the door being open? I can't remember if it is that or the key being removed the ignition. Maybe then you could wire it up so the noise for the light only goes if the light is on and the door is open - and if the lights aren't on the noise wouldn't go. Probably do that with a relay.
Fun to mess with anyway.
Old Oct 19, 2004 | 02:03 PM
image's Avatar
where can u buy a new chime? that would be cool. How hard is the install?
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
