New Coil Paks...WOW
Old Oct 19, 2004 | 07:49 AM
MaxSE99's Avatar
New Coil Paks...WOW
I have had my Max for almost 3 years now and recently one of the coil paks went bad. I just got the new ones on today (Thank You Nissan Certified Warranty!) and I must say that it makes one heck of a difference with the new ones. Even before the one went bad it didnt run this good. Its just ashame they cost so much to replace for normal maintence.
Old Oct 19, 2004 | 08:14 AM
Brudaddy's Avatar
I should probably do this soon.
Old Oct 19, 2004 | 09:48 AM
tropheus_guy's Avatar
I got a set of 6 new coils on ebay for $200 cdn. The dealer charge was way to high. I replaced all six of mine when 1 went.
Old Oct 19, 2004 | 10:06 AM
vipervadim's Avatar
I like Maximas
yeah my new coils smoothed out the acceleration and responce. Get the Mitsubishis not the Hanshins.
Old Oct 19, 2004 | 12:17 PM
d50ross's Avatar
Where Is The Best Place To Get The Coils For The Lowest Price.
Old Oct 19, 2004 | 04:09 PM
bckncook's Avatar
bump for an answer
Old Oct 19, 2004 | 05:22 PM
amulla01's Avatar
You get a few horse powers I would say lol, but I dont think they last long for 99 maximas (I m a victim too )
Old Oct 19, 2004 | 06:27 PM
bckncook's Avatar
I understand that a vast batch of 99's came from the factory with defective coils that will likely have to be replaced at some point, but I've never heard that the 99's create an environment that causes failure of new ones any quicker than in other model years.
Am I misunderstanding you, or are you saying that even if you simultaneously replace all 6 coils with new Mitsubishi coils, there is something specific to the 99 that will cause even the new coils to fail quicker than other model years?
I've got to replace my coils right away due to at least one bad one, but this will certainly impact my decision to replace just the bad coil or all 6, as well as whether I look for a used one or go all out on 6 new Mitsubishi coils.
So what's the facts, guys?
Old Oct 19, 2004 | 06:35 PM
amulla01's Avatar
yeah the coils need to be changed much more often than in other models. i changed all 6 at 70k mileage, now I got 88k
Old Oct 19, 2004 | 06:37 PM
PTownMax's Avatar
I still miss the max
this may be a stupid question but i don't know where the coils are, my haynes manual doesn't specify where it is so any help would be appreciated!
Old Oct 19, 2004 | 06:53 PM
Guinader's Avatar
yeah it is a stupid question, but I feel like answering.
the coils are the things that sit on top of your spark plug. that long rubber thing. if you still don't know what I'm talking about..
then just think like this.
the coils are connected to wires and the coil trows power into the spark plug in order for the spark to happen. I just can't remember names right now. so i can't be anymore specific.
had too many exams and I'm ready to go to sleep now.
Old Oct 19, 2004 | 07:46 PM
DavidT's Avatar
what are symptoms of a bad coil/spark plug?
I've noticed a lot lately when sitting at a stoplight, occasionally rpms will drop a bit with a very noticeable stumble of the engine. It is a very short and quick event. It will NOT do it in park/neutral.
Old Oct 19, 2004 | 07:50 PM
MaximaSE96's Avatar
Maxima Owner
TTT for cheap coils
Old Oct 19, 2004 | 08:00 PM
bckncook's Avatar
Never heard of TTT. Where do I find them?
Old Oct 19, 2004 | 08:56 PM
michaelnyden's Avatar
what is TTT?
Old Oct 19, 2004 | 09:04 PM
BlueC's Avatar
wat
hahaha... TTT = To the Top. He was bumping the thread.
$200 canadian is pretty good for all 6 new coils, where did you find them that cheap?
Old Oct 20, 2004 | 12:41 AM
Keyser Skoze's Avatar
yea, how do you know when your coils are going bad? I have 118k on mine and the interesting thing is that my last 98 MAX pulled harder then this one.
Old Oct 20, 2004 | 07:37 AM
well considering that I have replaced pretty much every filter and sensor there is on my car, the only thing left is my coil packs and injectors....I won't bother with the injectors cause those are being replaced with 370's soon when I S/C....but the coil packs I definitely want to replace and see what they do! if that doesn't fix it, then I will do a compression test...
Old Oct 20, 2004 | 12:07 PM
vipervadim's Avatar
I like Maximas
amulla01:
i've never heard that 99 Maximas kill coils much quicker than all the others. where did you get that bit of information?
From all the research i did on the web and on the .org the reason why 99's have bad coils is because of cost cutting. Nissan went with cheaper manufactured coils to save money on cost of production per model. that's why so many owners of 99's had to replace their coils after 75K+. after replacing the bad 99 Hanshin coils, nobody had any problems. the only reason i can think of coils going bad so quickly is a problem with the wiring harness or the car's electrical system.
DavidT, Keyser Skoze:
the symptoms you are encounteering are the same ones i was, the dreadded hiccup. you have at least one bad ignition coil. You can test out each individual coil with a multimeter, there is a guide in the haynes manual on page 5-7. each of the coils should have similar resisance except the bad one. You can determine the bad coil that way. I had two bad coils, one which had a very loose and had left more residue on the old plugs (when i changed them 8K miles before) so i replaced all 6 coils in case any others went, and my car became very smooth under idling and linear on acceleration and pulls very strong.
BTW i got my coils from Courtesy Nissan (972-644-3942) they offer a big discount for maxima.org members and each coil came out to be about $57 bucks (front and rear are different)
Old Oct 20, 2004 | 12:19 PM
Turk's Avatar
WOW my 1995 maxima has over 160,000 and the same old Coil Packs. I gues they were having problems on the 1999 models. Well good luck people.
Old Oct 20, 2004 | 12:30 PM
TheMax95's Avatar
Originally Posted by vipervadim
amulla01:
Thanks for the good info! I'll have to check out my coils sometime.
-Paul
96 SE 5speed i/y
14.762
93.8
Old Oct 20, 2004 | 01:04 PM
amulla01's Avatar
amulla01:
So they used the cheap coils (hanshin)? How long do the other brands last for then? If hanshins last for 70k I ll probably be happy with them again lol. Anyways, I just said it cause my nissan service manager that said that they get a lot of problems with engine coils for these maximas (he sees it every day I guess).
Old Oct 20, 2004 | 04:05 PM
DJMaxGLE's Avatar
This is PRECISELY what I experienced. Still do. Not as bad as in the past though. It's very random. I took my car to Midas and the Stealership and both places said they're fine. The Stealership said it could be a bad AAC-something or other. Some guys here on the org suggested it could be a bad fuel filter. I'm just saying that it might not be the coils. I'm waiting until the "hiccups" become really noticeable. Midas quoted be about ~$265 to change them, so we'll see.
Old Oct 20, 2004 | 04:19 PM
drunkenmunky23's Avatar
vipervadim, could you do a write up or scan the pages in the haynes manual?
do you guys thing it would be my coils if my car stalls (5spd) sometimes wen i come to a quick stop?
Old Oct 21, 2004 | 09:02 AM
TheMax95's Avatar
this happens to my car too. It doesn't stall but the rpm's dip pretty low, to around 400rpm then it goes back up.
-Paul
96 SE 5speed i/y
14.762
93.8
Old Oct 21, 2004 | 09:43 AM
BlueC's Avatar
wat
I have 63k miles, and this will be the second time i'll be replacing a coil pack. I first saw the problem around 51k miles, so they dont always last over 75k miles.
Old Oct 21, 2004 | 10:27 AM
bckncook's Avatar
But you didn't replace all 6 when you had the problem the first time, did you? If you only replaced the problematic coil at the time, it isn't surprising that you're having the problem again with another coil. Did you just replace the problematic one or all 6 last time?
Old Oct 21, 2004 | 11:01 AM
PTownMax's Avatar
what current am i looking for when i try to ohm ehm out?
Old Oct 21, 2004 | 11:58 AM
vortechpower's Avatar
ive got a 99 with 102000 and have no problems with my coil packs. Been boosted for 95000 miles
Old Oct 21, 2004 | 01:25 PM
PTownMax's Avatar
anyone got an answer?
Old Oct 21, 2004 | 02:04 PM
naijai's Avatar
95 with 195000 on original coil packs no problems
Old Oct 21, 2004 | 04:04 PM
DavidT's Avatar
no Hayne's here, do you have more detailed info please... pretty please
Old Oct 21, 2004 | 05:40 PM
Zack342's Avatar
US 1999 guys should get a group buy going...... we need to unite and show the rest of the 4th gens what us 99's can do.
Old Oct 21, 2004 | 06:00 PM
CUSEMAX's Avatar
davet it is MOST LIKELY the coil packs... that is exactly what happenned to my 99, it ran like crap, but when i put it in neutral or park it was fine... when i replaced the coil packs, it started running awesome again....
Old Oct 21, 2004 | 06:02 PM
gabex's Avatar
id be down for a group buy on coil packs.. $60/ea is too expensive
Old Oct 22, 2004 | 02:27 AM
I'd be down for a group deal on these...
Old Oct 22, 2004 | 06:38 AM
bckncook's Avatar
I'm in for a group deal.
Old Oct 22, 2004 | 08:19 AM
maxAmillion96's Avatar
I'm in for a group deal. I actually have a post up in the group deal forum asking for someone to start a group deal on coil packs but no one is responding.
Old Oct 22, 2004 | 08:24 AM
Zack342's Avatar
well lets try getting in touch with some of the nissan dealer guys on here and see what we can do. Its a know problem on the 99's and well it can't hurt to replace them on any car.
Old Oct 22, 2004 | 12:13 PM
nismomax98's Avatar
i had a problem with the rpm when i come to a stop, what i did was replace the TPS or throttle position sensor and the problem went away. there is a site with the procedure on the org somewhere just look
