buying 5 spd 95 maxima
Old Oct 19, 2004 | 07:18 PM
kwk4life's Avatar
I am about to buy a 5 spd 95 maxima with 156k on it. I heard that the 4th generation maxima does not have a timing belt but timing chain. is that right? what do i need to do to this car running for at leat 3 more years? Thank you.
Old Oct 19, 2004 | 07:21 PM
guyincognito's Avatar
you are correct, no timing belt it has a timing chain, I think Nissan stopped using timing belts in 93?
Old Oct 19, 2004 | 08:24 PM
95stillenmax's Avatar
dude just take care of it its good for at least 100k more
Old Oct 19, 2004 | 08:46 PM
amulla01's Avatar
I m just interested for how much is he selling it for?
Old Oct 19, 2004 | 08:49 PM
Loe max's Avatar
Nah, Nissan still uses belts, just not on the VQ series engines.
To keep it runing in tip-top shape, do a basic tune-up:
-spark plugs
-air filter
-fuel filter
-throttle body cleaner
then go further:
-sea foam
-o2 sensor check
-knock sensor check
-egr check
-check your cat
-check your down-pipe flex section
-check suspension components
you get the idea, all of the above are DIY's
Old Oct 20, 2004 | 06:35 AM
kwk4life's Avatar
Thanks. I am buying it for $3300.
Old Oct 20, 2004 | 07:36 AM
Loe max's Avatar
thats a good deal, also check to brake fluid and coolant. The brake fluid is one of the most overlooked item with maintenence so if its dark, have it flushed and changed. Same with the cooling system because if it failed, it can be a very $$ fix.
ah2002
Mar 9, 2016 01:42 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MikesChevelle
Aug 14, 2015 12:31 PM
Supragte
Aug 12, 2015 10:00 PM
