High idle at red lights
Old 10-22-2004, 04:47 PM
jackazz's Avatar
My max has a wierd idle. When you start the car it idles normally (ie a little higher when it's cold but drops down once it reaches operating temp). Over the last few weeks it has developed this issue where after I drive at speed, sometimes over a long distance and sometimes between lights, and come back to a stop, the idle is high (1500rpm or so). If I blip the throttle it goes down to where it is supposed to idle (750rpm?). Gas pedal doesn't stick or anything. Any input is appreciated.
1995 Maxima SE
181,XXX miles
5 speed
No Mods
jackazz is offline
Old 10-24-2004, 08:11 AM
tom_98se's Avatar
PCV valve?
I had some idle troubles after I changed a PCV valve @ the 60k service. They would drop to 300-500rpm while shifting (I have a 5-speed.) So I replaced it again and my idle problems went away. Actually, it idles a little high when it's cold but then settles down later.
Just a thought. It's a $4 part and changing it takes 5 minutes.
Good luck,
TOM
tom_98se is offline
Old 10-24-2004, 09:11 AM
njmaxseltd's Avatar
Could be a sticky IACV.
Clean your throttle body and the IACV valve.
njmaxseltd is offline
Old 10-24-2004, 09:43 AM
Do I get a tax break?
njmodi's Avatar
on the sticky IACV... mine did exactly the same thing (high-idle in stop/go traffic, etc.). I took off the IACV and gave it a good scrub with some throttle-body cleaner (not carb-cleaner)... I also cleaned out the TB at the same time... its been fine since.
njmodi is offline
doctorpullit
04-05-2017 12:59 PM
220k+ A32
08-17-2015 03:57 PM
beboski
08-16-2015 05:23 PM
doobadoo
08-15-2015 06:43 PM
MikesChevelle
08-06-2015 11:36 AM
Quick Reply: High idle at red lights
