My TPS is 570 ohms, leave it or adjust?
Old Oct 22, 2004 | 11:23 PM
Nismo's Avatar
I tested my TPS at closed throttle and it was 560-580 ohms, Now should I adjust it down or is mine within reasonable spec?
Old Oct 22, 2004 | 11:56 PM
DAVE Sz's Avatar
Hooooooonda.....
The FSM says ~500ohms. What is it at WOT?
Old Oct 23, 2004 | 02:45 AM
meccanoble's Avatar
Sports Button FTW
i was playing wit mine today too and i stripped one of the bolts, obviously the one furthest away and hardest to get to. any recommendations on getting that POS out?
Old Oct 23, 2004 | 06:30 AM
I30tMikeD's Avatar
take a pair of vice grips to the bolt.
Old Oct 23, 2004 | 06:31 AM
I30tMikeD's Avatar
I would try back probing the sensor and seeing what voltage you get.
Old Oct 23, 2004 | 08:26 PM
izzydig's Avatar
What ur saying is, that your tps is between 12 and 16% off. Just my opionion, but I feel the nissan engineers don't work with the idea that all their systems should have a 12-16% tolerance. <3-5% tolerance? sounds good to me. I went from 596 ohms at idle, to 517 ohms at idle. It's kinda tricky to get it perfect of course.
You don't take off your TPS to adjust it.
My little screws were on tight. I used a ratchet with a screw attachment and 2.5inch extension to get it off. This ratchet is shorter than most screwdrivers, perfect for that tight spacing. I used a brand new bit, that fit perfect for the heads. The screws cracked/loosened without a hitch. I tried with my trusty/favorite screwdriver first, but realized right away, I was going to end up with some stripped heads if I didn't use a better tool.
Edit: This weekend I'm gonna try to get it dead on 495-505 ohms. I adjusted it previously at 11pm, with a flashlight.
Old Oct 23, 2004 | 08:56 PM
99maxk2's Avatar
How do you exactly test these and change the position of it. I read the write-up on it, but i still dont quite get it. Can someone please explain?
Kyle
Old Oct 24, 2004 | 10:42 AM
99maxk2's Avatar
Bump.... anyone?
REDinLV
Aug 15, 2024 12:30 AM
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
