Replacing Stock Exhaust???
Old Oct 23, 2004 | 09:21 PM
rbeyer's Avatar
Ok, time to replace the stock muffler. I don't want anything too loud, but something with a litttle more purr then stock would be nice. Suggestions???
Is there any exhasut to get the car to sound say like the G35's/300z's? From my own research I hear MagnaFlow is a decent replacement choice for the mild note I'm seeking. Ohh, and I have a Budget Y-Pipe if it makes a difference.
Old Oct 24, 2004 | 08:33 AM
rbeyer's Avatar
Anyone?
Bump
Old Oct 24, 2004 | 08:36 AM
2 Da Max's Avatar
world sports is a quiet *** muffler
Old Oct 24, 2004 | 02:56 PM
Terran's Avatar
Dynomax superturbo. With a resonated B-pipe it is just a bit louder than stock. I think it's perfect...just what I wanted.
Old Oct 25, 2004 | 07:24 PM
rbeyer's Avatar
Does the Dynomax sound smooth... i.e. no droning sound or strange backpressure. From what I've read I think I will like this set-up for the stock replacement. Now I just need to order it and a tip I guess.
Any other suggestions out there? What about the Dynomax compared to a stock 5th gen muffler I could buy?
Old Oct 25, 2004 | 07:31 PM
MDeezy's Avatar
just out of curiosity what exaclty causes back pressure? is it just too much pressurein a restrictive piping?
I met a guy with the 350Z gutted cat, and he had some bad back pressure when he reved high in neutral.
Old Oct 25, 2004 | 07:51 PM
GodFather's Avatar
Made in Taiwan
back pressure exists when there are obstacles in the exhaust piping, for our maxima, it's the precats in the stock y-pipe that creats immediate backpressure. this back pressure will slow down the exit flow of the exhaust gas coming directly from the combustion chambers. this back pressure isn't good for a racing-based vehicle because too much back pressure will push the combustion exhaust back to the chamber itself resulting in blown gaskets and such. some serious cases may be blowing the piston rods. back pressure also exsts when piping is too small to allow exhaust passage. the dealer service shop tells me to keep some back pressure in the exhaust for engine to perform normal. i didn't understand it at all. i only thought back pressure is only bad for the car. in thermodynamics class, i learned that for maximum thermal efficiency, we want to achieve the carnot engine cycle. this in detail has to do with why do we contain back pressure to an extent. basically, the engineers that constructed the engine power cycle is keeping performance and efficiency well balanced. higher performance will cut the fuel efficiency and vice versa. we are car enthusiasts, we start cutting fuel efficiency and persue performance. word...
Old Oct 25, 2004 | 08:51 PM
MDeezy's Avatar
wow, thanks for the very inepth explanation of backpressure.
I understand it more, but dont understand why we need any at all, I guess the answer to that might be a loong reply? but I understand backpressurenow for sure.
that Z guy I met I belive kept stock pipping but upped the power on his Z by a lot, (ECU, Intake, other stuff I cant remembert).
When you say we are enthusiasts and start cutting fuel effiency are you refereing to when we put a Y-pipe on? and if so cutting fuel efficeince meaning were improving or decreaseing economy? I alway heard we get a little bit better gas economy with a Y-pipe (after market one)?
Old Oct 25, 2004 | 09:35 PM
maximabest's Avatar
get the apexi catback and ws y pipe...is the best setup for maximas.
Old Oct 25, 2004 | 09:41 PM
deadman.inc's Avatar
whts a catback? sorry noob...... is it like the "B" pipe?
Old Oct 25, 2004 | 09:43 PM
jdm71488's Avatar
oh yes, the absolute best... you sure know your stuff... btw, he's aready got a budget y...
i agree with the dynomax supertubro and resonated b-pipe... i pretty much have a clone of that system by WSP and i like the sound of it... nice and quiet...
Old Oct 25, 2004 | 09:44 PM
jdm71488's Avatar
y-pipe > cat > o2 sensor (97-98 i think) > b-pipe > axle back / muffler > tip
i caught a glimpse of the o2 sensor on mine and it looks to be as my diagram () above shows... a whole seperate piece, cuz i know the o2 sensor on 95-96 is on the cat itself... am i right?
Old Oct 26, 2004 | 12:46 AM
happyricefob's Avatar
V^___^V
http://maxmods.dyndns.org/index.php?MaximaPerformance
Old Oct 26, 2004 | 03:17 AM
oooooooo, i got wht a catbak is!! sweet! thanksssssssss
now... wht do they mean when they say 'resonated'?
Old Oct 26, 2004 | 09:01 AM
larryseibel's Avatar
i have a warpspeed muffler that i like the sound of. its barely audible over the sound of the intake...got some grunt to it. but its the quiet one they sell so im not exactly sure who makes it.
Old Oct 26, 2004 | 09:23 AM
joew's Avatar
it appears that apexi catback is for 95 & 96.
Old Oct 26, 2004 | 03:53 PM
rbeyer's Avatar
I think I'm going to order the Dynomax superturbo and try that out. If I have a Budget Y-pipe and stock everything else which size do I get?
(2 1/4") or (2 1/2")
I guess I will need to buy a tip for the exhaust as well..any suggestions where to buy for a good price?
Old Nov 1, 2004 | 09:00 AM
rbeyer's Avatar
Bump... Anyone know what size muffler to order give the stock b-bipe. What diameter? (2 1/4") or (2 1/2").
I want to order this dynomax and get it installed very soon. I just need to find a tip as well, guess I'll swing by the muffler place and see what they have.
Old Nov 1, 2004 | 09:32 AM
97WhtSE's Avatar
i dunno i think u have to get a adapter from the stock piping to get it to fit the 2"1/4 inlet of the muffler but i could be wrong. I dunno the diameter of the piping of the OEM b pipe is.
Old Nov 1, 2004 | 09:40 AM
BlackCat's Avatar
RIP '98 Maxima SE
I've got the Budget 2.5" Y-pipe and B-pipe with a 14" Magnaflow resonator and the stock muffler. IMO the noise level is exactly the same as stock.
Old Nov 1, 2004 | 10:31 AM
SPiG's Avatar
SomePsychoGuy
concerning backpressure: http://forums.maxima.org/showpost.ph...1&postcount=33
Old Nov 1, 2004 | 01:14 PM
jdm71488's Avatar
i guess the install went good then
JRod28
Dec 29, 2023 09:56 PM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
george__
Aug 18, 2015 07:06 PM
