Question about reading the TPS
Old Oct 26, 2004 | 05:17 PM
99maxk2's Avatar
How exactly do i do this? When reading ohms, where does the key have to be in the ignition? obviously i cant start the car since there is a TPS connection disconnected. Can anyone give me a quick write up on how do exaclty test my TPS. Thanks, its MUCH appreciated.
I read the "How To's," but i can't understand it to well, the instructions aren't clear enough to me.
Old Oct 26, 2004 | 06:42 PM
99maxk2's Avatar
bump........
Old Oct 26, 2004 | 06:45 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
turn the key to ON and test the sensor.
Old Oct 26, 2004 | 07:01 PM
UTIMaxima's Avatar
If you're checking resistance, (ohms), you want the circuit isolated, no power. Ign off.
Old Oct 26, 2004 | 07:05 PM
99maxk2's Avatar
so how do i do that?
Old Oct 26, 2004 | 07:16 PM
UTIMaxima's Avatar
Do you have a multimeter? If so, put it to ohms, red lead on pin 2, black lead on pin 3. Foot off gas pedal, Ignition OFF, sensor disconnected. You should get 500 ohms. as you press gas pedal, resistance will go up, reaching approx. 4000 ohms at wot.
Old Oct 26, 2004 | 07:20 PM
Vlasic's Avatar
crap. ya he is right. the ign needs to be ON when checking volts. sorry.
Old Oct 26, 2004 | 07:28 PM
99maxk2's Avatar
cool thanks man, really appreciate it. Im gonna go do that right now
Old Oct 26, 2004 | 07:29 PM
UTIMaxima's Avatar
have fun....
Old Oct 26, 2004 | 07:46 PM
99maxk2's Avatar
yea.. my TPS is right oh the money. i got 505 ohms and 3943 at WOT. Im guessin it is my Fuel injectors that are causing my problem. but thanks for the help.
Old Oct 26, 2004 | 07:53 PM
UTIMaxima's Avatar
No problem dude. BTW, what kind of problem are you having, what have you done so far?
Old Oct 26, 2004 | 08:24 PM
99maxk2's Avatar
My RPMs fluctuate when I slow down and idling. I idle at around 500-550, which i think is really low and sometimes my RPMs will drop below 500 and give my car a jolt, which causes the "fluctuating"
So far i have cleaned my TPS sensors to make sure there is a good connection and i cleaned my Throttle Body about 2 months ago. Im getting Fuel induction service real soon, so im hoping that is the issue.
Old Oct 26, 2004 | 09:46 PM
Vlasic's Avatar
try cleaning your IAC valve, EGR, and cleaning or replace your PCV valve.
Old Oct 26, 2004 | 09:59 PM
DAVE Sz's Avatar
Hooooooonda.....
Ignition is supposed to be off when checking the sensor.
Old Oct 26, 2004 | 10:03 PM
Nismo's Avatar
http://vbxmaxima.8m.com/tps.html
Old Oct 26, 2004 | 10:28 PM
I30tMikeD's Avatar
Just for the outside chance, check your ECU screw and make sure it is turned in the correct direction. It happend to me before and having the screw in the wrong spot will do funny things to your idle. It has happend to others as well, and they think I am crazy when I tell them to check it. It just seems that us org guys check our codes so much that we sometimes just leave the screw in the wrong spot.
Old Oct 26, 2004 | 10:32 PM
f550maranello2's Avatar
Yep ur absolutely right man u cant check resistance with an electrical load
Old Oct 27, 2004 | 10:27 AM
99maxk2's Avatar
aight cool, which way is the screw supposed to be. Im guessin all the way to the right... right?
Old Oct 27, 2004 | 05:13 PM
UTIMaxima's Avatar
All the way to the left
captchaos
Mar 15, 2016 12:18 PM
I<3 A32's
Sep 10, 2015 11:07 AM
crazyespn
Sep 3, 2015 01:30 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
