valve cover gasket leak?
Old Oct 27, 2004 | 06:30 AM
DcMaN's Avatar
can anyone help me i believe that a few people told me i have a valve cover gasket leak on my 95 maxima GXE. if anyone can confirm this pelase let me know asap. http://photobucket.com/albums/v374/D...t=DCP_0881.jpg
and no i didnt paint the engine silver. I bought it like that.
Old Oct 27, 2004 | 08:02 AM
Dubbya's Avatar
VK56 Inside
Ok, since you said you didnt paint your engine like that I wont say too much about it. But buy some paint thinner and a a$$ load of rags and go to town on that! As for the oil leak....I am guessing you are talking about the front Valve Cover. I see a little bit of build up there, nothing that looks overly concerning. Gasket from the factory is cheap. Install is easy. Just buy a Chilton manual. The front one should take like 20 minutes to do. If its the rear Valve Cover then its a considerable amount harder. You have to take off the Plenum (upper intake).
Dub
Old Oct 27, 2004 | 08:03 AM
NmexMAX's Avatar
dot dot dot ...
Mine is 3x as bad ( the buildup ) . Nice paint.
Old Oct 27, 2004 | 08:09 AM
njmodi's Avatar
Do I get a tax break?
Is that your engine's halloween outfit?
You gotta scrub that sh*t off man - its a disgrace to the VQ.
Old Oct 27, 2004 | 08:27 AM
JoeB
I have oil in my spark plug holes. Valve cover gasket???
Old Oct 27, 2004 | 08:28 AM
NmexMAX's Avatar
dot dot dot ...
Blow-by .
Old Oct 27, 2004 | 09:04 AM
DcMaN's Avatar
dont laugh at my engines color . Stupid little kids spray painting it silver what a *** :\ whoever did that. Anyway how critical is this valve cover gasket leak should i get it fixed asap or what ? And ask for the paint i want it off so bad lol . but im afraid ill mess up something. Ill try the paint thinner solution though. Is their anything else ?
Old Oct 27, 2004 | 09:22 AM
gtr_rider's Avatar
192.168.1.1
WTF?!
Old Oct 27, 2004 | 09:28 AM
Dubbya's Avatar
VK56 Inside
If you dont see oil under your car then I wouldnt be too concernded with a small leak. Get it fixed at some point before it is a major issue. As for the depainting of your engine. Thats gonna be tough. I would just start replacing hoses cause those will be impossible to clean. I would not use paint thinner on them. The other stuff....metal parts...take them to a paint shop and have them bead blast the snot out of it. That would be the easiest way. Other than that get out a drill with some sort of sander attachment. Good luck!
Dub
Old Oct 27, 2004 | 09:37 AM
95MAXIMASExy's Avatar
i have the same thing. In my case its from checking the oil and not wiping the oil off the dipstick when i put it back in, clean it up once and then notice that it originates from the dipstick insertion hole
Old Oct 27, 2004 | 09:38 AM
NmexMAX's Avatar
dot dot dot ...
Read my old post, and see, DON'T worry, mine is way worse and I have had no issues. Just calm down. . .
Old Oct 27, 2004 | 10:49 AM
njmodi's Avatar
Dub
Might be easier/cheaper to do an engine-swap
Old Oct 27, 2004 | 11:24 AM
Dubbya's Avatar
VK56 Inside
Right and push the old one off a cliff some where!
Dub
Old Oct 27, 2004 | 11:27 AM
s0ber's Avatar
LOL that engine is hilarious... Who the hell did you buy that car from ? lol
As far as the leak.. its a 30minute job, the gasket is about $15-20..
njmodi's Avatar
Dub
Maybe the original owner who painted it wants it back for his civic.
Old Oct 27, 2004 | 01:37 PM
DcMaN's Avatar
The dealer actually picked it up from an auction in Boston or Ny i forget which one. for the price i paid for the car *** the silver engine i can live with it i paid 3,800 for the car w/ 110k miles and 6month warranty He also did the timing chain and water pump for free. Yea the kid must of thought he had a civic, but the car runs flawlessly besides the fact that the idle is a bit high its around 1k. But hell ill throw around a couple hundred dollars even a couple g's to fix the minor stuff.
Old Oct 27, 2004 | 01:43 PM
NmexMAX's Avatar
dot dot dot ...
My idle is at 900 rpm. Auto. . .
Old Oct 27, 2004 | 01:50 PM
DcMaN's Avatar
so you think its fine then ? Mine is automatic too.
Old Oct 27, 2004 | 01:51 PM
NmexMAX's Avatar
dot dot dot ...
In Park/neutral, as for other gears its about 750-800
Old Oct 27, 2004 | 02:34 PM
DcMaN's Avatar
well mine was at like 1k while it was in gears. Im assuming theres a sensor that needs to be tweaked or replaceD ?
Old Oct 27, 2004 | 02:35 PM
FormorAccordMan's Avatar
That made me laugh.
Old Oct 27, 2004 | 02:37 PM
DcMaN's Avatar
ok ok ok enough about my engines color . Lets pretend its not silver atm. lol
tgreen
Oct 18, 2015 06:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
tardrex
Sep 11, 2015 07:35 PM
