Help! Key locked in ignition!
Old Oct 28, 2004 | 07:16 PM
smackdownGTR's Avatar
Guys I need your help/input. Just pulled into my driveway and turned car off and my damn key is stuck in the ignition. Yes. It is in the park position.
I was trying to get it out for half an hour with no luck. Also, now it only starts in neutral. I hope my transmission didn't fail.
Please let me know if this happened to any of you before.
btw.. it is an auto.
Thanks!
Old Oct 28, 2004 | 07:18 PM
Loe max's Avatar
Did ya move the steering wheel left to right?
Old Oct 28, 2004 | 07:30 PM
njmodi's Avatar
Do I get a tax break?
The switch that is detects that the car is in P is not working (I believe its called the Park inhibitor switch or something like that)... unless that switch triggers (when the car is in Park) you can't start the car and you can't remove the key from the ignition.
Old Oct 28, 2004 | 07:37 PM
Where can I find this switch and how much would it be to replace?
Yes, I did try to turn my steering wheel lef tand right to no avail.
Old Oct 28, 2004 | 07:50 PM
crajner's Avatar
pushed in that lil black button, right?
Old Oct 28, 2004 | 07:55 PM
amulla01's Avatar
just put the car on neutral and straighten the wheels... might push it a little too...
Old Oct 28, 2004 | 08:06 PM
What little button are you talking about?
Old Oct 28, 2004 | 08:08 PM
DAVE Sz's Avatar
Hooooooonda.....
He's a moron, autos have no little button.
Old Oct 28, 2004 | 08:11 PM
Taken2DaMax's Avatar
Try to wiggle the steering wheel left and right. Sometimes the ignition lock needs the wheel to be straight in order to let go of the key.
Old Oct 28, 2004 | 08:16 PM
I tried that. I even drove around the block. This is really frustrating. I know what you mean by that wiggling the steering wheel. I wonder if worst case scenario how much it would cost to repair at the dealer?
Old Oct 28, 2004 | 08:48 PM
PAREDLINE's Avatar
i had the same thing happen to me. it was on a date.
so instead of paying attention to my date I was frantically trying to get my damn key out of the ignition.
Turns out the girl left her chap stick in front of the shift lever. It was on park but the chap stick had wedged itself in there so it wasnt all the way in park.
There's a mechanical cable (I think) attached to your shift lever. Once the shift lever goes to park the cable releases a lock in your ignition lock and the key comes out.
I dont see why you cant disable the whole thing. Just remove that cable. I get confused between my Olds LSS and the I30. I think the Nissans have a cable and the Olds have a switch.
Maybe the other way around. Anyway open the thing up and try to disable the thing.
Its annoying too
Old Oct 29, 2004 | 06:58 AM
njmodi's Avatar
Yes - I double checked in the Haynes manual last night (bedtime reading) - there is an ignition lock cable that runs from the shift lever to the ignition lock - that cable might have broken, disconnected from one of the two ends or might not be moving freely... get yourself a Haynes manual - they have all the instructions you need (not complicated at all) to diagnose and fix that problem yourself...
Old Oct 29, 2004 | 10:54 AM
emoore924's Avatar
I vaguely recall that there is a procedure in the (Haynes/owner's) manual for removing the key when the P lockout has failed. It involves a button on the underside of the steering column and some coincident manuvering of the shift lever. Don't recall the details.
Check the owner's manual. There's an easy fix for this.
Old Oct 29, 2004 | 11:07 AM
crajner's Avatar
autos so did. my 88 max had one and it was auto
Old Oct 29, 2004 | 11:47 AM
DAVE Sz's Avatar
Hooooooonda.....
?Autos so did? A 88 max isn't a 4 th gen. 4th gen autos have no button.
Old Oct 29, 2004 | 01:22 PM
Maxima99SE's Avatar
will fly for food
i have no little button.
Old Oct 29, 2004 | 03:04 PM
Ant96GLE's Avatar
Wow I cant believe you guys dont know the solution to such a simple problem. And autos dont have buttons... sigh
Press the brake and move your shifter all the way down to L and back up to park, Your key will come out. The cable gets jammed and the car thinks its somewhere between park and reverse and wont let the key out.
Old Oct 29, 2004 | 04:20 PM
Kevlo911's Avatar
Kevlo for President
Old Oct 29, 2004 | 06:41 PM
DAVE Sz's Avatar
Hooooooonda.....
Shift to L? What's the L stand for, let go? Stop making the kid go paranoid looking for a L by his shifter.
Old Oct 29, 2004 | 11:55 PM
Ant96GLE's Avatar
L is 1st gear
Excuse me I have to idiot proof everything here
AaronL
Aug 8, 2020 10:31 AM
Fbana41
Aug 29, 2016 12:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
