My Car Still Won't Start
Old Oct 28, 2004 | 08:15 PM
maxs4life's Avatar
Last week my car won't start 4 nothing, even before that i ve always had a hard time starting it. I was told that it was a cranksensor, I replace both and nothing I t just will not start
It cranks like it want to start but NO NO NO NOTHING.
i changed spark plugs ngks 1 month ago
then changed again to bosch yesterday
changed fuel filter
cleaned out my intake and TB
put it on the scanner and nothing no codes at all
switch ECU nothig at all
won't start
mechanic tells me that it could be a lose wire
like finding a needle in a haystack
right
need help please
Old Oct 28, 2004 | 08:18 PM
mansurxk's Avatar
changed fuel filter
won't start
right
need help please
like i said before, did you check the camshaft position sensor also? did you clean both crankshaft positoin sensors as well? you need to check resinstances, maybe the one you got from the junkyard was dead, i had hard starting, and then it just cranked and never started til i cleaned those sensors, they had metal shavings all over. you need to do a check on them again, also try to check the ground between the engine and tranny, or reground everything.
Old Oct 28, 2004 | 08:30 PM
maxs4life's Avatar
FRIEND WHO IS THE MECHANIC HAS A MAX HE REPLACE THE SENSORS WITH HIS NOTHING. AND I DID THAT BEFORE, CLEAN THE SENSORS NOTHING. IF THE SENSORS WHERE BAD THE CODES SHOULD POP UP RIGHT.
Old Oct 28, 2004 | 08:53 PM
amulla01's Avatar
maybe time to call a toe to dealership?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
