95 Timing Chain
Old Nov 1, 2004 | 08:51 AM
sjharr's Avatar
95 Timing Chain
1995 Maxima GLE with 155K miles
recently had been encountering some noise from the timing chain area. While visiting the dealer for an oil change had them diagnose the noise. Dealer says the timing chain, guides and water pump, while they are in there should be replaced, at a cost of $1700. Does this seem like a fair price for the Charlotte ,NC area?
also, once the timing chain goes on this engine, doesn't it mean the engine is near the end of its life anyway?
Still trying to decide whether or not to dump $1700 more in my max. Love the car though, she is the third one i have owned.
Thanks in advance
Steve
Old Nov 1, 2004 | 09:01 AM
lex4style's Avatar
i think there was a recall on the timing chain for 95 maximas. Mine has a similar rattle when i start her up.
Old Nov 1, 2004 | 09:46 AM
koolranch's Avatar
PM me for help
Hey I live and work in the Charlotte area... PM me and I will get up with you and give you some better options... if there is a recall I would love to hear about it.....
Kool
Old Nov 1, 2004 | 09:59 AM
NismoTunin's Avatar
yea same here i would like more info on that recall if theres one... please PM me if u have any additional info thanks... i would love if they repaired that for me cause then i would get about another 100K outa my max...
Old Nov 1, 2004 | 10:29 AM
njmodi's Avatar
Do I get a tax break?
There is no recall... there might be a TSB - basically the timing chain tensioner and possible the chain guide need to be replaced. You should be able to find a shop that will replace the waterpump, tensioner and guide for about 500-600 bucks.
Old Nov 1, 2004 | 10:30 AM
Jatan's Avatar
Ummm stay away from the stealership... They like to rape you up the you know what...
There is NO recall on this, only a TSB: http://forums.maxima.org/showthread.php?t=267096 but $1700 is way too much. Head over to the regional section of the forum and ask your local people on where to get it fixed for a cheaper price.
Old Nov 1, 2004 | 10:45 AM
MAXRB8's Avatar
I had mine done recently, the shop rate for labour is 6.5hrs, I changed the guide and chain. No your motor is not near it's end because of this, lots of people are getting 300k and more. Some ppl have done it themselves but it's no easy job for someone inexperienced, my mechanic said it's such a confined area to work in he had to tilt the motor and in hind sight would have considered removing the fender.
Old Nov 1, 2004 | 07:05 PM
yhtan76's Avatar
Question: Does 4th gen max needs to change timing chain? I got this from the Stickies FAQ
http://forums.maxima.org/showpost.ph...8&postcount=26
Old Nov 1, 2004 | 07:44 PM
pedroboe's Avatar
one of the reasons i got a Max is because I researched here and someone said the timing chain was meant to last the life of the engine and that's a good thing....
Old Nov 2, 2004 | 06:08 AM
Stephen Max's Avatar
The timing chain does not need to be changed. The only thing that needs to be replaced if you are getting the rattling noise is the main chain tensioner. You don't need to replace the guide, either.
Old Nov 2, 2004 | 06:12 AM
95bluse's Avatar
Stephen is correct. I recently replaced my tensioner alone and posted a write up in this forum. I't's a DYI job, but the area is tight to work in, so patience is needed. I'm going to find the link & post it.
Here you go...
http://forums.maxima.org/showthread.php?t=348244
Old Nov 2, 2004 | 07:45 AM
sjharr's Avatar
Thanks to all of you for your quick responses. This forum ROCKS!!
Couple more quick questions....
I grabbed a copy of the TSB (many thanks to the poster)
TSB indicates to change the tensioner and timing chain slack guide, also gives the part numbers. Can you guys suggest a good supplier to purchase these parts from. My plan is to get the parts on hand then shop the job to some local nissan techs. Also, would it be beneficial to go ahead and replace the water pump as well? oh yeah, one other thing, will any major damage be done if i keep driving until i get this fixed?
Thanks in advance
Steve
Old Nov 9, 2004 | 09:32 AM
ukmastermind's Avatar
in addition to replacing the pump/tensioner/guide, i'm looking into new timing chain and sprockets.
Old Nov 9, 2004 | 12:10 PM
THT's Avatar
THT
Throbbing member
www.jerryromenissan.com and use the promo code "MAXIMA" to get 25% off of list price.
~THT
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
