Where did you guys put your switches
Old Nov 2, 2004 | 07:45 AM
sunten1
I was wondering where all you people put your switches for your Neons, and leds cuz i just can't find a good place to put these switchs.....ohh ya for all you who did the leds in the vents mod well what did you use for power....a picture wouldn't hurt...me noob at this wireing thing,.....
THanx in advance
Old Nov 2, 2004 | 07:52 AM
MDeezy's Avatar
you could put your switches anywhere you want.
It depends on whether you have tools to maybe so come drilling and such.
For a Clean look you could get a rocker switch and in between the switches for the heated seats (assuming you have an empty slot their like in my SE) you could put a rocker switch in their so that its clean and in a good position.
if not I've seen some good photos of poeple who put the swithes in that flip out ash tray, that looks good and stylish.
just some ideas.
Old Nov 2, 2004 | 08:27 AM
sunten1
bump before i got to work......ok i found a good place to put the switches...now for the power source????
Old Nov 2, 2004 | 08:29 AM
2 Da Max's Avatar
i put my switches by the armrest
Old Nov 2, 2004 | 09:02 AM
ny96max's Avatar
from the left:
-whelen strobe kit on/off
-strobe flash pattern changer
-microvision tv on/off
-dvd player on/off
-taillight flasher on/off
...all have LED indicators so i know when everything is on or off
old school pic:
and
this pic is well over a year old. I no longer have the aluminum dash kit in, i have replaced the upper clock piece to get rid of that gap and also have shifted the tv down about 1/4"+ to center it more in the opening. So no flaming on any of that please!
Ant
Old Nov 2, 2004 | 09:23 AM
image's Avatar
Switches
#1 Neons under dash
#2 Neons Under seat
#3 Neons in Trunk/Backseat Plexi Hatch
#4 Neons for underbody glow (Coming soon, just got the gold series kit in by SG )
Old Nov 2, 2004 | 09:37 AM
chenzarino's Avatar
right now my foglight switch is dangling from under my dash, so i just crammed it up there.
Old Nov 2, 2004 | 09:45 AM
A32Matt's Avatar
this was the switch for my DR.
Old Nov 2, 2004 | 09:59 AM
Linkage23's Avatar
The ash tray is the best, cleanest looking spot for a switch or two! Ny96Max has the right idea! looks hot and incognito to say the least.
Old Nov 2, 2004 | 11:00 AM
MDeezy's Avatar
Ny96max has a good thing going.
Hey Ny96max where did you get those switches from? did they come with the bulbs to indicate if its on or not, or did you add that feature yourself?
Old Nov 2, 2004 | 11:07 AM
DJMaxGLE's Avatar
Neons = teh ghey haha. j/k. Your car, your money. That's pretty creative how you guys arranged some of your switches. Good work.
Old Nov 2, 2004 | 11:51 AM
ny96max's Avatar
the switches and LEDs are left parts over from alarm installs i do at work. Every switch on there trips a relay which does the actual work for turing power on for each unit installed. The LEDs i just set up to pop on when the switch is thrown to the on position, i needed to use a 1,000ohm resistor to get them at the brightness i wanted.
Ant
Old Nov 2, 2004 | 12:27 PM
1FSTMAX's Avatar
cup holder
Old Nov 2, 2004 | 01:49 PM
1MAX2NV's Avatar
Ignited switch panel.
Old Nov 2, 2004 | 02:02 PM
2 Da Max's Avatar
wow sexy... where did u get that dash kit from man?
Old Nov 2, 2004 | 02:07 PM
RA030726's Avatar
I'm nutty for Nissans
Look to the left by the dead pedal, see the red switch. This is my manual fan switch for use at the track. It's in the kick panel. This is the same spot I had the DR for the 96 auto.
A closer view
I also used the blank spot next to the dimmer, push button start...
And finally I have mounted switches to the bottom of the knee bolster. I used regular rocker switches, 96 had remote starter overide and wig wags while the 98 has a rear fog switch.
Old Nov 2, 2004 | 02:31 PM
sunten1
ok people thanx alot and now for the power source for the leds in the vents???
Old Nov 2, 2004 | 04:21 PM
sunten1
bump come on dudes
Old Nov 3, 2004 | 10:19 AM
1MAX2NV's Avatar
Evolution autodesign. Click on the sponsor link above.
Old Nov 3, 2004 | 10:30 AM
Batxel's Avatar
blah
cup holder
how much current are your led's going to draw?
you could use your power wire for the radio, but it would always be on
Old Nov 3, 2004 | 11:44 AM
sean05's Avatar
nymax, where did u get the piece to mount the switchs to?
Shock_and_Awe
Aug 23, 2015 01:02 PM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
