Slave cylinder going out.....I think
I got in my car this morning and the clutch felt pretty weird.
It was just a little squishy.
Also, it would not go in gear.
I immediately thought about my brother's slave cylinder going out one time in his VW and it acting just like this.
Here are the symptoms:
1. clutch is squishy
2. clutch does not seem to want to come all the way out sometimes
3. will not go into gear(obviously) because of the clutch.
4. clutch engages almost at the floorboard where before, it would engage when it was almost all the way out.
Do we have Hydrolic clutches or mechanical?(I am almost positive it is hydrolic because of the fluid resevoir under the hood....which is full, BTW.
What do you think is wrong based on the symptoms?
Any other things to look out for?
**If it is the slave cylinder, I think my brother and I can do that pretty quickly. I guess at this point, I am kind of hoping that is what it is.
Thanks for any help.
We have hydraulic. Check your clutch fluid. It is in the small master cylinder near the right (facing the car) side of the firewall. If it is empty then you probably have a leak.
It is most likely the rubber line connected to the slave cylinder. I just used a SS line from a GD and bought a new slave cylinder just in case.
http://www.motorvate.ca/mvp.php/802
GD for SS line:http://forums.maxima.org/showthread.php?t=338081
It is a little better when it is warm.
Not that much.
I just talked to the guy at the dealership. He said if the resevior got too low for some reason, it would have sucked air in. If I bleed it, it might just be solved.
Not that much.
HYDRAULIC Seams to be right up there along with breaks on this forum. ![Roll Eyes (Sarcastic)](https://maxima.org/forums/images/smilies/rolleyes.gif)
Spelling 101.![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
See if there is any air in the line by bleeding the system first. Usually the slave cylinder doesn't just fail, it starts to leak. At that point you wind up with the condition you have after the reserve runs out and you suck in air.
If you bleed the system and you still don't have enough pressure to release the clutch, the clutch master cylinder might be at fault.
Spelling 101.
Spelling 101.
Spelling 101.
Sorry about the spelling errors. ha ha. I will try to keep up with that better from now on....esp when talking about my hydraulic clutch. ha ha.
When you say that the Master cylinder "might" be at fault, do you think it is the most likely scenario? Or could it still be the slave cylinder as the culprit?
Thanks,
Yeah, I know it would be better to just do it all while I am under there with everything apart, but I just really don't want to replace anything if it does not need it....ie the master cylinder. That thing is not that expensive, but by the time I got the hoses and both cylinders, it would be like $200.
Just trying to keep from having to do that.
I guess if worse comes to worse, I can do that.
It is still not that bad for maintenance.
Well, I just ordered a Slave cylinder from NAPA.
Nobody but the dealership stock it in town, so it will not be here until tomorrow.
I will go home tonight and bleed the lines for the slave, and probably the master cylinder to see if that cures what is ailing my baby. If that does the trick, I guess I will tell NAPA to just keep the slave cylinder.
Any of you ever tried this clutch bleeding with a power/speed bleeder.
My brother has one and we have done his clutch and brakes. We will probably try that tonight. It is so fast and easy.
I'm having this problem but I just finished my 5spd conversion recently. I just bought the slave and master cylinder from JerryRome Nissan for like $127 Shipped. I have a straight hydraulic line from master to slave cylinder. I also had used cylinders.
Few Questions out there.....
I had someone that told me to use Dot3 Fluid for Clutch Systems..any Input....
Does anyone know how to gravity bleed a line. From what I know is that you flip a new bottle of brake fluid into the resiouvor and open up the bleeder and wait all day long.........
Chris
Chris
Spelling 101.
ha ha ha.
That is funny.
Dentalstud, I have not seen you on here in a while.
I don't know if you remember, but I think I tried to buy a maxima from you back at the beginning of last year?
______________________________________________
update:
Looks like the air in the line was the culprit....I hope.
I bled the line and it seems to be back to normal again.
I just hope that is all there was too it, and it is not one of the cylinders.
The resevoir had aparently gotten just low enough that a heavy turn probably sloshed the fluid around and got some air in there.
All clutch pressure appears to be back and functional.
Will update though.
(thanks for help all)
That is funny.
update:
Will update though.
When I bled my clutch I used DOT3 Brake fluid. While I was at pepboys I saw what they called clutch fluid which was like 3x as much (like $3.00 for a cup of it). Is this so called clutch fluid better? or worth it?
I think brake fluid is supposed to just be used.
That is what I have always heard.
Jeff92se, Thanks for all the help, man.
I am going to keep an eye on the resevior and see what is going on with all that.
So far, through the weekend, nothing has happened. I will keep you posted.
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
knight_yyz
11-01-2015 01:34 PM
